Fully ported/valve job #198773
01/20/09 09:18 AM
01/20/09 09:18 AM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
Is 800 bucks a good price for fully ported 452 heads? How much Horse power can you typically gain from fully ported heads? Engine is a 440.
Re: Fully ported/valve job [Re: wtucker] #198774
01/20/09 09:30 AM
01/20/09 09:30 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Is that to do them or buy them completed?? sounds reasonable 30 to 50 hp depending on a lot of other factors.
Re: Fully ported/valve job [Re: Dodgem] #198775
01/20/09 09:40 AM
01/20/09 09:40 AM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
That is to do them, assuming there are no cracks and they are still good enough to be done.
Re: Fully ported/valve job [Re: wtucker] #198776
01/20/09 10:41 AM
01/20/09 10:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you aren't getting much for 800 bucks unless the head porter only charges 5 bucks an hour .
in my area that 800 is for a basic rebuild with all new parts on bare castings
Re: Fully ported/valve job [Re: wtucker] #198777
01/20/09 10:43 AM
01/20/09 10:43 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
thats with new 2.14/1.81 stainless valves and new guides??
Re: Fully ported/valve job [Re: Dodgem] #198778
01/20/09 02:50 PM
01/20/09 02:50 PM
Central NC
gch Offline
gch  Offline
Central NC
I would'nt touch them with a 10 ft pole without having them checked out by a trusted machinist and have one cylinder flowed so you know what you have.
Re: Fully ported/valve job [Re: gch] #198779
01/20/09 03:46 PM
01/20/09 03:46 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
800 bucks goes a long way towards a purchase of edelbrock rpm heads or 440source heads.
Re: Fully ported/valve job [Re: DaytonaTurbo] #198780
01/22/09 01:18 AM
01/22/09 01:18 AM
dogdays Offline
dogdays  Offline
R.
Re: Fully ported/valve job [Re: wtucker] #198781
01/22/09 02:15 AM
01/22/09 02:15 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
I had a set of ported 452 heads from
Line Performance (Jason Line, before the Prostock
days)13-14 years back. Not to much to pick from
back then. Eddie RPM's were a new thing, and 440-1
heads from Indy were just to much money.
I think I had about $1500 or so into the 452's.
Eddie RPM's fully ported will out flow fully
ported 452's.
452's fully ported should push 600 HP in a 440.
$800 is a good deal if they are in good shape
and flow what you need. Have them flow tested.
What is the combo your building?
Snap your neck, mega G-force launch, is all I want!
Re: Fully ported/valve job [Re: wtucker] #198782
01/22/09 03:19 AM
01/22/09 03:19 AM
& they are still open chambered heads.
Re: Fully ported/valve job [Re: RapidRobert] #198783
01/22/09 03:58 AM
01/22/09 03:58 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Are you certain his work will yield good results? A member here who is a professional posted some pics of some home ported heads. The ports looked fantastic but the flow bench revealed an insignificant improvement over as cast. Any reason you are not considering a new set of stealth heads?
Keep old mopars alive.
