What mini starter to use for my 440 ? #1987103
01/09/16 08:03 PM
01/09/16 08:03 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
working on my 1978 Ramcharger with a 440. had a regular starter but went bad. Had to take off headers to remove. Want to install a mini. went to autozone. They have a small one that's for a 360 in a 92 dodge truck for $68, then they have a 360 for 1996 one for a $100. ? different part numbers. same specs. Anyone know the difference??
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: What mini starter to use for my 440 ? [Re: hulmule] #1987113
01/09/16 08:23 PM
01/09/16 08:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I would think the difference would be the connectors. Have them show you both and compare.
Re: What mini starter to use for my 440 ? [Re: hulmule] #1987240
01/09/16 11:46 PM
01/09/16 11:46 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The difference is one is heavy duty watt rating from what I
see.I run a 99 360 one on my 440.Its been on since 99 or so.My kid bought a new one from 440 Source for like 60 some bucks.Had it in the 413 for about 4 years and sold the car.Never a problem.Rocky
Chrysler Firepower
Re: What mini starter to use for my 440 ? [Re: hulmule] #1987290
01/10/16 01:03 AM
01/10/16 01:03 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've used several for a 95 Dakota 5.3 on big blocks.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: What mini starter to use for my 440 ? [Re: moparmarks] #1987386
01/10/16 03:46 AM
01/10/16 03:46 AM
What Stump said, check the connectors & iirc something about you can take off the bakelite connector to gain access to more compatible terminals underneath it for an easy connect to our traditional large ring terminal and small ring terminal combo starter cable, then get the $68 one at AZ
Re: What mini starter to use for my 440 ? [Re: hulmule] #1987445
01/10/16 11:37 AM
01/10/16 11:37 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Al,ost all have the connector.Its easy to remove.Most you have to cut the studs down or gr d the block a bit.I just cut about 1/8 off the studs on my 440.I think the one for Source just slipped in on the 413 my kid had.There are many listed on Ebay also for cheap.Quite a few guys have bought them with no problems.Rocky
Chrysler Firepower
Re: What mini starter to use for my 440 ? [Re: hulmule] #1987447
01/10/16 11:37 AM
01/10/16 11:37 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Almost all have the connector.Its easy to remove.Most you have to cut the studs down or grind the block a bit.I just cut about 1/8 off the studs on my 440.I think the one for Source just slipped in on the 413 my kid had.There are many listed on Ebay also for cheap.Quite a few guys have bought them with no problems.Rocky
Chrysler Firepower
Re: What mini starter to use for my 440 ? [Re: hulmule] #1987455
01/10/16 12:04 PM
01/10/16 12:04 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use the regular 5.2 starter. Spins my 572, 14.8-1, 34 degrees w/o retard with the ignition switched on.
Doug
Re: What mini starter to use for my 440 ? [Re: dvw] #1987538
01/10/16 01:52 PM
01/10/16 01:52 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I bought one from the JY for 25 bucks it turned over my 14-1 race car for many years and hundreds of starts and was still working when I sold it.i did have to grind down the starter lug but it was no big deal.i use them on all my big blocks
Re: What mini starter to use for my 440 ? [Re: hulmule] #1987893
01/10/16 08:53 PM
01/10/16 08:53 PM
NC
1970A66 Offline
1970A66  Offline
NC
I have been using one of these:
http://www.dbelectrical.com/p-1318-new-m...66-snd0088.aspx
You could try calling them to ask about your application.
Re: What mini starter to use for my 440 ? [Re: 1970A66] #1987912
01/10/16 09:32 PM
01/10/16 09:32 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive bought some things from them as well,great customer sevice,no hassle return policy.
Re: What mini starter to use for my 440 ? [Re: bonefish] #1988066
01/10/16 11:58 PM
01/10/16 11:58 PM
Indianapolis
Waveraider Offline
Waveraider  Offline
Indianapolis
Originally Posted By bonefish
I bought one from the JY for 25 bucks...
+1
Re: What mini starter to use for my 440 ? [Re: Waveraider] #1988332
01/11/16 11:46 AM
01/11/16 11:46 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
+1
+2
Re: What mini starter to use for my 440 ? [Re: hulmule] #1989292
01/12/16 03:45 PM
01/12/16 03:45 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I got a used mini from a caravan six and it runs great with no problems cost me 25$
Re: What mini starter to use for my 440 ? [Re: hulmule] #1993892
01/19/16 03:09 AM
01/19/16 03:09 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
I'm running one from a 90 D250 on my 440...works great!
Re: What mini starter to use for my 440 ? [Re: hulmule] #1993908
01/19/16 04:59 AM
01/19/16 04:59 AM
Ohio
lockjaw-express Offline
Ohio
I bought the RobbMC Starter, and it clears everything, and is super powerful. Very impressed with their producs.
Mark
