You can't screw up primer......can you? #198634
01/20/09 12:15 AM
01/20/09 12:15 AM
Tri-Cities, Washington
V
VITC_GTX Online content OP
VITC_GTX  Online Content OP
V
Was planning on sandblasting my motor compartment and doors/jambs. Right after I plan on blowing all sand off the car(I know this will take a while to get it all out), use wax and grease remover on it and use DP40 then K36 filler primer. After that I will work on completing the rest of the body work.
I have a Finex gun that I have only used once so I have limited experience.
My question is you can't screw up primer can you?? If I use the P-sheets to mix things appropiately it's about impossible to screw it up, correct?
Re: You can't screw up primer......can you? [Re: VITC_GTX] #198635
01/20/09 12:47 AM
01/20/09 12:47 AM
Jacksonville Florida
elitecustombody Offline
I'm sure one can screw up ,there are things to consider,like water filter to keep moisture out of airlines,blowing off a car with unfiltered air,applying primer too heavy,not letting it flash or sags and runs,spraying too dry, but it's alot more forgiving than paint/clear
Re: You can't screw up primer......can you? [Re: elitecustombody] #198636
01/20/09 03:01 AM
01/20/09 03:01 AM
dulcich Offline
dulcich  Offline
I'd skip the wax and grease remover and go right to the primer
-dulcich
Re: You can't screw up primer......can you? [Re: dulcich] #198637
01/20/09 08:44 AM
01/20/09 08:44 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
-dulcich
For sure on bare sand blasted metal, that would only make it worse.
Re: You can't screw up primer......can you? [Re: VITC_GTX] #198638
01/20/09 11:28 AM
01/20/09 11:28 AM
O
OLD318 Offline
OLD318  Offline
O
This depends on what your interpretation of
"screw it up" is? and what your interpretation
of the finished result is...
If sand in your finished primed engine
compartment is ok for you than
....no you can't screw it up..
Sandblasting the engine compartment is ok.
But afterwards I would recommend a 4 step
cleaning/prep process after blasting it..
First, take the car outside or to a different
place and blow it off... blow it off for hours if you have to.. The blast media gets everywhere
Every hole you have in the frame, core support etc
Blow it out multiple times...
Take your time... don't be in a rush
Blow it, blow it, and blow it again....
Next, if you blasted with a heavy duty blast media like Aluminum oxide to get rid of heavy rust...
I would go over every inch (possible) with a DA
and 320 grit to get rid of the rough surface this stuff leaves behind..
if you used something finer to blast with you may not need to do this..But this is a great step
as it removes all the remaining surface "stuff" left behind by blasting... It leaves the surface really smooth too...
Next, I would go over the whole thing with PPG DX579 which is a metal prep/cleaner.
You apply it wet with a rag, and then wipe it dry with a clean one... you'll want to use a lint free rags for both of these steps...
Merfin makes a box of shop wipes that are EXCELLENT for this... but they are EXPENSIVE...
Third, after the wipe down with the DX579..
it's like an acid prep, you'll want to neutralize
the surface so I would repeat the wipe on wet,
wipe off until dry with PPG reducer like DX870
or any other reducer (does not have to be the high
priced stuff at all...just neutralize with reducer
wipe on wet, and wipe off dry (different rags)...
Take you time on these two steps...
Your basically cleaning the S#@# out of it which will lead to an outstanding result...
Next, blow the car off again and then wipe off
with your wax and grease remover...again
wipe on wet and wipe off dry with a separate rag.
I would not spray an engine compartment or the interior, trunk or door jams with K36 first..
I would use 2-3 coats of DPLF epoxy primer.
After that, wait a day or so, then paint...
I would paint right over the DPLF...
You don't have to use the expensive DBC paint
for an engine compartment, you can use DBU which is about half the cost... spray 3 coats and then
spray 2 coats of clear like 2021...
You'll LOVE the results...
Just my
Re: You can't screw up primer......can you? [Re: VITC_GTX] #198639
01/20/09 05:56 PM
01/20/09 05:56 PM
Columbus Ga
reflections7 Offline
Columbus Ga
Make sure the temp is above 60 or it wont cross link harden correctly even if you heat it up later. 2k products go thru a chemical reaction and have to be above that temp to work correctly.
Re: You can't screw up primer......can you? [Re: reflections7] #198640
01/20/09 06:33 PM
01/20/09 06:33 PM
Delaware
crazy4carz Offline
crazy4carz  Offline
Delaware
Be sure to use an epoxy primer rather than a solvent based primer. Also use a sandable fill primer and block it out.
Re: You can't screw up primer......can you? [Re: reflections7] #198641
01/20/09 08:37 PM
01/20/09 08:37 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I agree make sure the temp is right so it cures right before top coating it.
Skip the wax grease remover what is it Dx330 in PPG, just use laqure thinner to wipe it down since you will proberly have some spots that got dirty when you touching it and leaning on it were blasting the engine bay.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: You can't screw up primer......can you? [Re: 340SIX] #198642
01/20/09 09:56 PM
01/20/09 09:56 PM
Kentucky
Sasquatch4406 Offline
Kentucky
i believe its dx101
Re: You can't screw up primer......can you? [Re: Sasquatch4406] #198643
01/20/09 10:59 PM
01/20/09 10:59 PM
340SIX Offline
340SIX  Offline
DX330 Acryli clean is the wipe down i just looked in the cabinet and i have a can
Re: You can't screw up primer......can you? [Re: 340SIX] #198644
01/20/09 11:11 PM
01/20/09 11:11 PM
V
V
Consensus seems to be that I blast it, blow the beejeezes out of it to remove sand(using dry/filtered air), use a wipedown like laquer thinner (not wax and grease remover), DP40 it then K36(epoxy primer) in an area that is at least 60 degrees.
Hopefully I can handle that
What tip do you folks prefer to use for K36?
Re: You can't screw up primer......can you? [Re: VITC_GTX] #198645
01/21/09 12:13 AM
01/21/09 12:13 AM
340SIX Offline
340SIX  Offline
You can keep tons of sand out the holes if you duct tape in few layers over the holes in the frame while blasting.
Put the 2K {K36}primer on within 3-4 days in weather conditions hot as long as 7 when cold with out scuffing past this time it must be scuffed to stick.
Yes i know it is cold right now just giving that info for when you use it in the summer{later on}
Re: You can't screw up primer......can you? [Re: 340SIX] #198646
01/21/09 01:29 AM
01/21/09 01:29 AM
V
V
I can spray the 2K over the DP within a matter of hours, correct?
Re: You can't screw up primer......can you? [Re: VITC_GTX] #198647
01/21/09 04:55 AM
01/21/09 04:55 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I thought DP40 was an epoxy primer?
I agree that with good clean metal, that a wipe down with laquer thinner should be good once the blast media is cleaned out.
I have used the etching primer before coating with DP40 on some pannels where I stripped the paint with sandpaper and I was concerned about the crevices that I could not get to really well. With media blasting this may not be an issue?
Re: You can't screw up primer......can you? [Re: 451Mopar] #198648
01/21/09 11:36 AM
01/21/09 11:36 AM
V
V
I was using DP40 as an etching primer with K36 over that. I believe they are both epoxy
