Re: 500 inch b1 carb size [Re: JesseR] #1970591
12/16/15 12:56 AM
12/16/15 12:56 AM
Mark Whitener Offline
For nitrous I don't suggest you run a 1250 until you get to the 580" or bigger range. With a 1250 the throttle moves less to run the same RPM as a 1050, and so it runs on the transition circuit to a higher RPM before the boosters start to flow. You can certainly make one work with custom booster inserts, but until the displacement is larger I don't think you will see any difference, and it will make tuning with a tight converter real sensitive. NA with a lot of converter, no problem.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: 500 inch b1 carb size [Re: Al_Alguire] #1986142
01/08/16 05:26 AM
01/08/16 05:26 AM
Boise
thegodfather Offline
Boise
FWIW my 525 B1 had a 2.100 Throttle blade and made right at 1100hp. CFM wise it was in the 1180cfm range. I prefer three circuit carbs myself as it fits what I do. Some will argue that point and I understand their reasons, bit for me I prefer the third circuit.
PM message waiting for you Al. Thx.
