Re: Post your street strip 2nd Gen Hemi combos
[Re: 70VcodeCoronetRT]
#1986200
01/08/16 12:06 PM
01/08/16 12:06 PM
Posts: 314 Northeast Indiana
73DAD
Northeast Indiana
My current build nearing fruition. 528, early '70 factory heads unported but casting flash/protrusions removed, some used rocker assembly pieces but mostly new indy stuff, diamond pistons making about 10:1 with cometic head gaskets, reconditioned factory conrods (couldn't stomach using Chinese rods and couldn't afford American ones), a used stroker crank ground -.010 rods and mains, early 66-67? intake with Vanke modification, edelbrock 1407 carbs with '66 afb lids, some used, rough hooker super comp headers. I haven't bought a cam yet, but I'm looking at lift numbers .550-.600, lsa 110-112, and duration @.050 between 245-255.
It's going into a lightened '70 RR and my realistic goal is 12's this year. Later I plan on upgrading to aluminum heads with a single plane and single carb to hopefully make it into the 11's.
I bet barton's cam will have much more duration along with better flowing heads than i'll have. Depending on the rest of your combo, high 10's may be a reasonable goal.
#1986218
01/08/16 12:42 PM
01/08/16 12:42 PM
Posts: 12,200 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have been collecting parts for years for my Hemi project to replace the 500" wedge in my '70 Cuda. I found a new World iron block and MP al heads on Racingjunk. I had the heads ported by MCH a few years ago on their last "holiday deal". Then found a used Barton intake, a set of DLI rockers, a pair of DC valve covers, a good set of used spark plug tubes, used fuel pump, dist, etc.
This winter it is finally time to order the reciprocating assembly, cam, and other pieces of the puzzle. I have talked to several of the Hemi builders about the stroker kit and cam combo and was surprised at the different approaches to the same end.
Ultimately, I ordered a 10.5:1 540 kit and stepped up flat tappet cam from Ray Barton. I think the 528 has a 4.15 stroke and the 540 has the 4.25 stroke. They were basically the same price, so I went with the longer stroke.
I can't wait to get this puppy finished and in the car. WOO-HOO!
Master, again and still
[Re: 73DAD]
#1986435
01/08/16 06:07 PM
01/08/16 06:07 PM
Posts: 43,241 Bend,OR USA
Cab_Burge
Of course you don't need 528, but the bigger the displacement is, the milder the rest of the engine can be. The OP wants a street & strip engine. The bigger the C.I. and the more power and torque you make the easier the rear tires will spin Trust me on that My old 1970 Cuda 4 speed NHRA legal went high elevens(11.79 at 117. MPH) back in 1975 on nine inch bias ply slicks with 4.10 gears, that rascal had 2180 lbs on the front tires and 1280 lbs on the rear tires without the driver It was a real tire spinning rascal
[Re: 73DAD]
#1986545
01/08/16 09:53 PM
01/08/16 09:53 PM
Posts: 12,400 Taxes & Virus's R-US, NY
Dragula
605 all Aluminum Hemi pump gas street/strip build here... https://board.moparts.org/ubbthreads/ubbt...ld-updated.htmlMine...Is back out of the car for an unintentional cam update...Shooting for +800hp on pump gas...I did get some driving on it before a lobe on the cam left probably due to the fact I did not remove the inner springs during break in.......Wow is all I can say as it is an absolute beast. If mid 10's is all you want, we have been running 10.52 out of our 474 pump gas Hemi street engine...Does nice 2ft wheelies as well on those runs in a '69 A body that is for sale.
[Re: PorkyPig]
#1986587
01/08/16 11:16 PM
01/08/16 11:16 PM
Posts: 1,505 TN
SCATPACK 1
TN
The OP needs to provide more info on the car. You can run high 10s in a street and strip E body with an OEM-head 440 with the right combination. Ahhh... 10's with a factory 440 and OEM heads??? I am calling BS on that comment. The OP asked what others were running so he could get some idea's for his build.
Old Geezer Racing
[Re: SCATPACK 1]
#1986640
01/09/16 12:33 AM
01/09/16 12:33 AM
BradH
The OP needs to provide more info on the car. You can run high 10s in a street and strip E body with an OEM-head 440 with the right combination. Ahhh... 10's with a factory 440 and OEM heads??? I am calling BS on that comment. The OP asked what others were running so he could get some idea's for his build. I already posted what I had that fit the description of a 440 with ported OEM heads that could run high 10s, so there is nothing bogus about that. BTW, he didn't say "factory" 440, he said a 440 with OEM heads.
[Re: 73DAD]
#1986648
01/09/16 12:46 AM
01/09/16 12:46 AM
BradH
So if I've got all this straight, and bear with me here I'm a little slow, the OP shouldn't build more cubes than he needs because excess power will overwhelm his tires, and instead he should build a smaller engine with a looser converter and drag gears for his street/strip car.
By golly I've been going about this thing all wrong on my build too! Good thing you guys are here to set me right. Guess i had better dumpster all my hemi junk, buy a 318, and shove as much nitro through it as possible because it'll be just as fast. Who needs stinky ole displacement anyway!
On a serious note, if the OP is willing to buy a street oriented crate style hemi, it may be safe to assume the car in question is mostly for street driving with the occasional drag strip blast. If that's truly the case, I really think more displacement would better suit his goals.
I hope the OP chimes in soon so we don't have to guess. I hope the OP realizes that half the battle with getting any street car to ET decently is chassis tuning, tire selection and driver experience. Adding a big engine to an otherwise unsorted out combination is just asking for tire smoke and sub-par ETs. Any snarky comments to the contrary are delusional.
[Re: BradH]
#1986666
01/09/16 01:04 AM
01/09/16 01:04 AM
Dragula
[/quote] I already posted what I had that fit the description of a 440 with ported OEM heads that could run high 10s, so there is nothing bogus about that.
BTW, he didn't say "factory" 440, he said a 440 with OEM heads. [/quote]
It can be done, we have run 10.87 on a +.030 440 with OEM heads and a steel crank at 446 cubes....It takes work to do, and a good combination of parts. The car cannot be super heavy either and probably isn't the most daily driver friendly, but we have done it....With a stroker, the ET drops into the 9's on pump gas RB with after market heads.
[Re: 73DAD]
#1986668
01/09/16 01:05 AM
01/09/16 01:05 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I hope the OP chimes in soon so we don't have to guess. I agree with you as if you build a big torque monster you can go fast without pushing the eng to hard. Thats sorta what I did as I built my 493 so it would make enough power to get me in the 10's without pushing 7500 rpm or building a super trick build. It was easy on my budget and easily met my goal. I have no problem hooking on 9" slicks but I dont make the power a 528 Hemi will but I guess I make close to 600 flywheel hp. Ron
#1986718
01/09/16 02:36 AM
01/09/16 02:36 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I been going about it all wrong also, I got this 572 Hemi build going and I screwed up. For the same amount of money for the rotating assembly I could have bought a 604 stroker kit. Now I'm loosing sleep wondering how much power I lost making a uninformed decision. I 'm not worried about tire spin, if your just spinning your tires just driving around , your front brakes must be hung up.
[Re: rowin4]
#1986749
01/09/16 03:23 AM
01/09/16 03:23 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Mega block,68 stock irom heads,good valve train,reak good bottom end.9.5's at 144+ on pump gas @3900 lbs.Boost is where it's at
