piston to wall clearence #198554
01/19/09 10:40 PM
01/19/09 10:40 PM
Colorado
hemi69cuda Offline OP
Colorado
how much min, and how much max?
on a hemi piston?
Re: piston to wall clearence [Re: hemi69cuda] #198555
01/20/09 11:27 AM
01/20/09 11:27 AM
WA 98043
thecarfarmer Offline
WA 98043
Piston brand, CR, fuel, usage?
Not that it'll help me answer, but I know you'll be asked...
Here's a
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: piston to wall clearence [Re: hemi69cuda] #198556
01/20/09 01:59 PM
01/20/09 01:59 PM
on a hemi piston?
It depends Which brand and material and application, which type of block, Aluminum or iron I have seen guys run as much as .0115 and as tight as .0045 on the old TRW/Speed Pro forged high compression racing pistons that mopar recommended using .008 or higher
