Re: Another pcv valve question, 4.7L
[Re: 70duster340]
#198546
01/20/09 10:56 AM
01/20/09 10:56 AM
Posts: 2,936 Richmond, VA
VT_Dart
Richmond, VA
My wife's 4.7 has a bit of an erratic idle. It was getting really bad and replacing the TPS corrected the situation, but the idle still isn't completely smooth. PCV valve didn't remedy it either. My dad's 4.7 in his Dakota ('02) has a slightly detectable change in idle too, and has since new, so I'm wondering if it's just normal for the vehicle.
Darrah Heath
[Re: moparmandc]
#198549
01/20/09 02:39 PM
01/20/09 02:39 PM
VT_Dart
Richmond, VA
the ones that i have seen replacing the tps usually fixes it but you might try cleaning the throttle body also hope this helps. also have seen the pcv freezing up on these 4.7s lately not sure where you are from but changing it might not be a bad idea or at least cleaning it cause it does get a lot of moisture.
Good call. I also took off the throttle body and did a thorough cleaning when I replaced the TPS, just forgot to mention that.
[Re: 70duster340]
#198551
01/20/09 04:53 PM
01/20/09 04:53 PM
VT_Dart
Richmond, VA
Right now I am just trying to get the sensor off. I can't get the screws to break loose. Maybe if I run the engine up to operating temperature, it may help with those pesky screws? Cleaning the throttle body is a good idea, as well. However, here in Ohio it's only 20 degrees today. That's higher than it has been in at least a week!!!
Trouble on the TPS screws? Mine came right out, but maybe they're easier to get to on the Grand Cherokee than the Dakota. If it's anything like the GC, taking the throttle body off is a 10 minute job and probably worth the effort. Totally understand about the cold weather though, doesn't make working any fun.
