Re: Why won't it start?
[Re: Dodgem]
#198531
01/20/09 07:24 PM
01/20/09 07:24 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Make sure the Neutral safety switch is hooked up and working. it just grounds. You can find it on the solenoid "N".
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#198532
01/21/09 09:46 AM
01/21/09 09:46 AM
Posts: 173 Indiana
swepty
Indiana
I jumped across the terminals at the starter and nothing happens. I just ordered a new OE positive cable that has all of the ends already on it. I will switch that out, other than tat I am lost. Wouldn't the starter button I put in bypass all of the stuff like the neutral switch, since the button is wired straight from the battery to the starter? This is one of those deals that is soo simple that it is kickin my a**!!!!!
1976 CREW CAB 3/4 ton 4x4 Factory plow and ex Airforce Truck
1986 Power Ram 400hp 360 6" lift
1970 Plymouth custom suburban 318 4" drop
1996 Dodge 1500 360 4wd 3" lift
North Central Indiana Mopar Club member
[Re: swepty]
#198533
01/21/09 10:13 AM
01/21/09 10:13 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Test starter with jumper cables from positive on battery to big lug on fender mouted starter relay, and negative from battery to good ground on engine. Then jumber the big lug to the little lug on the relay to test the circuit etc. If it clicks and spins, your starter solinoid, starter, cable from relay to starter are good. Then look at wiring, relay etc by back tracking from there.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#198534
01/21/09 05:46 PM
01/21/09 05:46 PM
Posts: 173 Indiana
swepty
Indiana
Mine doesn't have lug style. It's the 6 ;pin solenoid that is all in cased like a relay. I will try from the battery down to the starter with jumper cables that should tell me whether the cable is ok or not. This is sooo frustrating.
