Rear Leaf Spring & Front Torsion Bar Recommendations Needed
#1984861
01/06/16 01:33 PM
01/06/16 01:33 PM
Posts: 1,563 Macomb, MI
vinnyd76
Macomb, MI
I have a 1970 Duster (originally a slant six) that will be upgraded to a 340 with a 727 trans and 8 3/4 rear axle (possibly 3.91 gear). A majority of the time, the Duster will be driven on the street to shows/cruises (maybe strip at Mopar events).
What type of rear leaf springs would you install on the vehicle? OE Leaf Springs: P4510268 and P4510269 or Competition Leaf Springs - Super Stock: P3412002 and P3412003?
With regard to the front torsion bars: P5249148 - Torsion Bar, 0.810" Diameter for A-Body P5249150 - Torsion Bar, 0.890" Diameter for A-Body P5249151 - Torsion Bar, 0.920" Diameter for A-Body
*If vehicle was used more for drag racing (with a stroker 340 kit), what would be your recommendations?
Thank you in advance for your feedback!
Re: Rear Leaf Spring & Front Torsion Bar Recommendations Needed
[Re: vinnyd76]
#1984922
01/06/16 03:27 PM
01/06/16 03:27 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I would run the biggest torsion bars you can get, something like a 1.06 because if you ever decide that you want something besides skinny tires it will handle better especially driving to events. Rear leafs, XHDs same leaf pack on both sides. Adjustable shocks....Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: vinnyd76]
#1984977
01/06/16 05:14 PM
01/06/16 05:14 PM
Posts: 5,337 the house on the left.
cogen80
torsion bar wise for the street the .920 will be a huge improvement over stock. but i'd go as big as i could.. even the 1" are on the soft side in my opinion.. for the track only put the smallest in it.. slant six size. for rear springs i'd call pete at http://www.bergmanautocraft.com/ and get him to set ya up with a set of the eaton springs he sells..
[Re: ahy]
#1985814
01/07/16 08:18 PM
01/07/16 08:18 PM
Posts: 1,770 Wethersfield,CT
Ray440
Wethersfield,CT
What size tires are you planning to use? For rear springs I recommend Espo springs. http://www.springsnthings.com/. I put the 1 inch over stock height rear springs on my Road Runner. Big improvement over the MP super stock springs I had on there before. The car rides much better and it hooks great at the track.
1969 Plymouth Road Runner 440 auto 2017 Ram 1500 Quad Cab 5.7 Hemi
[Re: vinnyd76]
#1985824
01/07/16 08:29 PM
01/07/16 08:29 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
PST's 1.03 Bars and their G-Max springs, great combo for a street car. Adjustable front shocks that you can dial back for the drag strip week-ends.
A new iron curtain drawn across the 49th parallel
[Re: mopardamo]
#1986136
01/08/16 04:51 AM
01/08/16 04:51 AM
RapidRobert
/6 bars for a dragger. for street/dd I had a 65 dart SB with SS 003/003 springs (came that way as a roller) & thick circle track t bars & it rode high and tight (I loved it), wouldn't change a thing
