Apache heads on a 5.7? #1984714
01/06/16 02:40 AM
01/06/16 02:40 AM
gregsdart Offline OP
After reading the other post on Apache heads, it sounds like the Apache heads have too big of a chamber to be used on a 5.7 block? I was hoping to use a set on a 5.7 core I currently have. I also have the Apache heads, new in the box.
Has anybody successfully run Apache heads on a 5.7 block, and what issues did you have?
Re: Apache heads on a 5.7? [Re: gregsdart] #1984853
01/06/16 01:25 PM
01/06/16 01:25 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I'm thinking the only thing you will need to do is get a cometic head gasket for a 5.7 block with a 4.10 bore. or whatever the 6.4 bore is and maybe notch the bore slightly
Re: Apache heads on a 5.7? [Re: gregsdart] #1984878
01/06/16 01:58 PM
01/06/16 01:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
Ask me again in a month...
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Apache heads on a 5.7? [Re: gregsdart] #1984900
01/06/16 02:50 PM
01/06/16 02:50 PM
Canada
Max Weg Offline
Max Weg  Offline
Canada
I will let you know in a day or so.
Max Weg
Re: Apache heads on a 5.7? [Re: gregsdart] #1985009
01/06/16 06:11 PM
01/06/16 06:11 PM
Re: Apache heads on a 5.7? [Re: gregsdart] #1985671
01/07/16 05:32 PM
01/07/16 05:32 PM
Canada
Max Weg Offline
Max Weg  Offline
Canada
I installed the appache heads on the freshly decked and honed block with a 0.025" gasket and measured the radial clearance at 0.032".
Max Weg
Re: Apache heads on a 5.7? [Re: Max Weg] #1985716
01/07/16 06:31 PM
01/07/16 06:31 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Nice! What bore size is the block?
Re: Apache heads on a 5.7? [Re: Max Weg] #1985719
01/07/16 06:38 PM
01/07/16 06:38 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Max Weg
cometic gasket?
Re: Apache heads on a 5.7? [Re: gregsdart] #1985724
01/07/16 06:43 PM
01/07/16 06:43 PM
Canada
Max Weg Offline
Max Weg  Offline
Canada
The Bore is 3.929" and I used a stock 5.7 gasket.
Max Weg
Re: Apache heads on a 5.7? [Re: gregsdart] #1986014
01/08/16 01:13 AM
01/08/16 01:13 AM
Did you check the gasket against the head to make sure the fire ring is out side the chamber? It must get real close!
Re: Apache heads on a 5.7? [Re: gregsdart] #1986348
01/08/16 04:01 PM
01/08/16 04:01 PM
Canada
Max Weg Offline
Max Weg  Offline
Canada
You would jot be able to use a 5.7 gasket. I was using it purely for its thickness as your not going to use a thinner gasket, therefore the radial clearance would be at it's worst.
Max Weg
Re: Apache heads on a 5.7? [Re: gregsdart] #2011828
02/14/16 04:40 PM
02/14/16 04:40 PM
Renton Washington
Renton Washington
Intake valve clears on my .010 over 5.7 with no head gasket.
We're going to eye brow the top of the bore slightly just because it should help unshroud the valve at low lift and provide more radial clearance.
Using a 4.100 Cometic for final assembly.
-Dustin
Re: Apache heads on a 5.7? [Re: gregsdart] #2012354
02/15/16 12:32 PM
02/15/16 12:32 PM
From what I understand, two things make notching the block for intake valve de shrouding of little value? First, the valve is moving away from the cylinder wall as it opens. Two, the flow on the short side radius of a port is very poor in most cases, although the Apache heads may have the best short side situation of any head on a stock motor. Still, I bet the flow difference would show very little power gain between notched and un notched bores.
Re: Apache heads on a 5.7? [Re: gregsdart] #2012427
02/15/16 02:10 PM
02/15/16 02:10 PM
Renton Washington
Renton Washington
Probably true, but the added radial clearance makes it worth doing IMO.
-Dustin
Re: Apache heads on a 5.7? [Re: Triple Threat] #2013064
02/16/16 12:48 PM
02/16/16 12:48 PM
Makes sense.
Depending on where the top of the top ring is, plus .040 for keeping the ring sealed under any situation, it might get a little tough to notch the block much. I assume though that the rings have to be moved down a lot lower than a stock type piston, so valve notches can be used for bigger cams? Anyone have an idea how far down the rings have to go? I hope to bore mine to 4.000 or close.
Re: Apache heads on a 5.7? [Re: gregsdart] #2046054
04/04/16 08:02 AM
04/04/16 08:02 AM
Bump, hope fully someone can provide info on my previous post?
"Anyone have an idea how far down the rings have to go? I hope to bore mine to 4.000 or close"
