Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1942758
11/01/15 10:08 AM
11/01/15 10:08 AM
moparx Online content
moparx  Online Content
Originally Posted By f2502011
Do the vacuum diaphragms have any markings, part numbers etc., on them? What does dual point mean and how can I tell if mine is dual point or not?
the diaphragm arm will have a number stamped on it indicating amount of advance breaker plate will move when vacuum is applied. dual point means you will have two sets of ignition contacts on the breaker plate instead of only one. this set up improves dwell angle of coil saturation.
beer
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: John_Kunkel] #1948733
11/10/15 02:22 PM
11/10/15 02:22 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
If I have to replace it I'll need to replace it with an original. Anyone know what part number I need to look for?
Manual Trans 3514265
Auto Trans 3620704
Anyone know what the difference is between these two? Mine is an automatic and I haven't been able to find a 3620704 but have found a 3514265.
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1948738
11/10/15 02:29 PM
11/10/15 02:29 PM
The only difference will be the amt of (total) adv the can offers (& it'll be stamped on the arm). You might be able to lookup the two different numbers (amounts of adv) & likely can live with/use either one and depending on if the number of the one you get is more or less than your orig bad one you can alter the amt of adv. decreasing it is easy, increasing it is hard(er) but can be done. this is a seperate mod than adjusting the tip in with the 3/32" allen wrench. EDIT What number is on yours and have them check what number is on the one that they do have (& post em)
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1948806
11/10/15 04:01 PM
11/10/15 04:01 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
As I try to get this thing tuned, another question is where is the best place to get a good intake manifold vacuum reading? I've tried the port on the carb for the vacuum advance and there is little if any vacuum there which could also be part of the problem unless that is normal? What should it be? Stock car, stock carbs stock cam etc.
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1948868
11/10/15 05:53 PM
11/10/15 05:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The vacuum advance port on the carb is ported vacuum,you won't get a reading there at idle,Take it off the PCV port on the carb or directly off the intake.If "nothing" has been modified you should have at least 17" or more. Also,
Incidentally,the Prestolite advance you posted above is for a big block,this is the correct small block advance.
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: 62maxwgn] #1949461
11/11/15 04:31 PM
11/11/15 04:31 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
What are the differences?
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1949490
11/11/15 05:15 PM
11/11/15 05:15 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Big block counter clockwise rotation,small block clockwise.The arm would be upside down and won't connect to the plate.
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1949899
11/12/15 11:47 AM
11/12/15 11:47 AM
US
f2502011 Offline OP
f2502011  Offline OP
US
Pulled my cap to take a look and used vacuum pump to help see what's going on. The VA doesn't do anything until about 8 and doesn't move anymore after 15. It's kinda jerky too and not smooth in its operation.
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1949901
11/12/15 11:54 AM
11/12/15 11:54 AM
US
f2502011 Offline OP
f2502011  Offline OP
US
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1949985
11/12/15 02:53 PM
11/12/15 02:53 PM
that is normal, you're in good shape (on this)
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1950040
11/12/15 04:43 PM
11/12/15 04:43 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
I would like to see what number is stamped on the arm but I can't see it with it together. I've never taken one of these apart before how does it come apart so I can see the arm, springs etc.? Is there anything special about it as far as disassembly? Is there a way to know how much advance the distributor has other than figuring it out with a timing light? I've set my initial timing to 10 btdc and I've revved it up to 2000-2500 rpm and it seems the timing wants to keep climbing beyond 36 so I didn't go any higher to see where it would stop going up. I'm used to GM distributors they don't look like this.
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1950084
11/12/15 06:28 PM
11/12/15 06:28 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you look down behind the condenser you can see it but it's not easy,it's probably stamped 8.I have four Prestolite 340 distributors and all stamped 8. The one I posted above is off an original 340-6 AAR.
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: RapidRobert] #1951006
11/14/15 12:05 PM
11/14/15 12:05 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
OMG please replace that burnt POS rotor
you need an original style hd body,riveted
real steel contact
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1984180
01/05/16 03:09 PM
01/05/16 03:09 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Finally getting around to replacing the vacuum advance. I was unable to find an NOS canister for the automatic but got an NOS 3514265. They look the same but the arm on
my original is an 8 and the one on the new one is 8.5. What do I need to do to set up the 3514265 to work as it should for my car?
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1984189
01/05/16 03:22 PM
01/05/16 03:22 PM
I doubt you will notice any pinging from the addit'l (1) degree you'd see on the crank (8.5-8=.5 x 2 = (1) deg. You can JB weld shims on either side of the notch in the arm on the case itself to limit the arms' travel & experiment with thickness till you see 16 addit'l on the crank when you plug in the can (you'd have it idling & plug the can into manifold just for this situation) assuming the chain and intergear slot/dist notch is tight so the mark ain't dancing around at idle so you can see exactly if the can is giving you exactly 16 (8x2)
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: RapidRobert] #1984253
01/05/16 04:41 PM
01/05/16 04:41 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
By chance does the diaphragm adjust with an Allen wrench to limit advance?
1970 EK2 T/A 727
Re: Vacuum advance diaphragm question/part number request 340-6 [Re: f2502011] #1984286
01/05/16 05:28 PM
01/05/16 05:28 PM
CCW with a 3/32" allen wrench slows when (in hg amt) the curve amt (8x2=16 degrees) starts by tightening the spring so it takes more vac to overcome that tension & there fore at what amt (in hg) the curve ends so in effect once you are in the curve by tightening the spring (CCW) you have less adv at any given in hg amt so likely that would quell any pinging if it did ping exp cuz we are very close on the amt. you would monitor this in eveyday driving under varying RPM/throttle (load) positions
