Re: TTI Headers for my 72 Challenger
[Re: patosmith]
#1983210
01/04/16 01:13 AM
01/04/16 01:13 AM
Posts: 4,848 Memphis
HemiRick
Memphis
with 505 cubes and good heads you probably want the bigger tubes.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: patosmith]
#1983283
01/04/16 04:07 AM
01/04/16 04:07 AM
Posts: 216 E. Okla line
m88mark
E. Okla line
I have a 400 B block that has been stroked to 505 in my 72 Challenger. I am using the Trick Flow 240 aluminum heads which have the exhaust ports in the stock location. I am looking at the TTI 400SR-218 headers which are good for 600+ HP. They also have the 383-178 which are good for 400 to 600 HP. I am leaning towards the 400SR-218 since they are the same price as the other set and I really don't know how much HP my motor will have. Has anyone used these in an E body? Any problems? Is there another brand I should look at? They also have a small list of starters they say will fit with these. I'm just looking for a little input before I pull the trigger on a $900 set of headers. Thanks for any advice you can give!
70 has PS mini, mine fit; not the big tube one though
