TTI Headers for my 72 Challenger #1983129
01/03/16 11:27 PM
01/03/16 11:27 PM
Spanaway, Washington State
P
patosmith Offline OP
P
I have a 400 B block that has been stroked to 505 in my 72 Challenger. I am using the Trick Flow 240 aluminum heads which have the exhaust ports in the stock location.
I am looking at the TTI 400SR-218 headers which are good for 600+ HP. They also have the 383-178 which are good for 400 to 600 HP.
I am leaning towards the 400SR-218 since they are the same price as the other set and I really don't know how much HP my motor will have.
Has anyone used these in an E body? Any problems?
Is there another brand I should look at?
They also have a small list of starters they say will fit with these.
I'm just looking for a little input before I pull the trigger on a $900 set of headers.
Thanks for any advice you can give!
Re: TTI Headers for my 72 Challenger [Re: patosmith] #1983210
01/04/16 01:13 AM
01/04/16 01:13 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
with 505 cubes and good heads you probably want the bigger tubes.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: TTI Headers for my 72 Challenger [Re: patosmith] #1983283
01/04/16 04:07 AM
01/04/16 04:07 AM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
70 has PS mini, mine fit; not the big tube one though
Re: TTI Headers for my 72 Challenger [Re: m88mark] #1983309
01/04/16 10:06 AM
01/04/16 10:06 AM
IN
ahy Offline
ahy  Offline
IN
I run the TTI 1 7/8" headers on a '70 Challenger with B engine and Edelbrock heads which also have exhaust in (near) the stock location. They fit as advertised and have held up well for ~12 years. For my engine, which is ~550 HP these are just right.
I considered 2" tubes but TTI did not have a 2" low deck option for OEM port location at the time.
Which one is right for you depends on your build and usage... a high effort drag engine with big cam could probably use the larger tubes. There is likely mid range torque advantage with the 1 7/8 tubes.
Either way, suggest you go for the ceramic coating inside and out. It really helps control engine compartment temps so wires and other stuff hold up.
Re: TTI Headers for my 72 Challenger [Re: patosmith] #1983712
01/04/16 08:54 PM
01/04/16 08:54 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
2" TTI headers had to be dimpled for the steering shaft and they touch the PS unit. If I had it to do again I'd go for 1 7/8"
