Freeze Plug tapping
#1982811
01/03/16 04:44 PM
01/03/16 04:44 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Anybody go to the trouble of tapping their freeze plugs? Looks like 1 5/8" is common size, would then if going typical to O ring boss #24, would need a 1 7/8"-12 thread. How tough to do and worth it? Make it easy for future reverse cooling if desired seems to me.
Re: Freeze Plug tapping
[Re: jcc]
#1983020
01/03/16 09:26 PM
01/03/16 09:26 PM
Posts: 3,505 DFW
mr_340
DFW
I guess if you have a CNC machine to threadmill the threads, then you can make whatever threads you want. That is a cool way to do it if your machine has a lot of Z travel. My HAAS only has 16 inches of Z, so I don't think I could get the block on the table and have any room for a tool. I might suggest a 1-11/16-16 UN threads. The 1-5/8" through hole would work great with that thread and leave 75% threads. http://www.efunda.com/designstandards/screws/unified.cfm?start=397&finish=472
Floyd Lippencott IV
[Re: jcc]
#1983035
01/03/16 09:37 PM
01/03/16 09:37 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
In Canada we just put a block heater in every freeze plug...
A new iron curtain drawn across the 49th parallel
