ms doesn't see the rpm? #1978811
12/29/15 07:56 PM
12/29/15 07:56 PM
Andrewh Offline OP
Andrewh  Offline OP
I finished wiring up a 5.9 magnum.
the distributor is a little different than stock. it has a shutter wheel in it instead of whatever is normally in a magnum distributor.
based on the wiring diagram diy auto tune supplied, I wired it in with all 3 wires.
common 5 volt, and then specific ground and sensing line on their shielded wire.
I can see voltage changes in the sensing line. but the tuner studio software doesn't seem to see anything.
I have a resistor wired in to the sensing line as well from how it was previously used.
sent them an email since there is no way to call, but wondering if anyone has any ideas on what to check.
Re: ms doesn't see the rpm? [Re: Andrewh] #1978894
12/29/15 09:43 PM
12/29/15 09:43 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Need to see the pickup. That saud, stock magnum would have been a hall effect type sensor. If the new one is 3 wire it is likely hall effect as well.
Angry white pureblood male
Re: ms doesn't see the rpm? [Re: ruderunner] #1978979
12/29/15 11:32 PM
12/29/15 11:32 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
magnum engines get the engine rpm from the crank sensor, distributor is basicly used for the injectors (aka cam sensor)
Re: ms doesn't see the rpm? [Re: moretoys] #1978994
12/29/15 11:45 PM
12/29/15 11:45 PM
Andrewh Offline OP
Andrewh  Offline OP
this is the pickup.
I realize it is the "cam' sensor, it worked for the old setup.
trying to make it work for the new.
it might just be that I don't have the right settings, or I didn't wire it right. not sure at this point.
the plug. is a 3 wire.
Re: ms doesn't see the rpm? [Re: Andrewh] #1979029
12/30/15 12:21 AM
12/30/15 12:21 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
need a 1k ohm pull up resistor between the power and signal pins. I had to do it on mine (using it as a cam sensor). It's the two outer pins.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: ms doesn't see the rpm? [Re: Andrewh] #1979032
12/30/15 12:22 AM
12/30/15 12:22 AM
Lake Orion, MI
Lake Orion, MI
oh another tech tip is if you want to test it you'll see the hall sensor switch state when you pass a razor blade through it.
Re: ms doesn't see the rpm? [Re: Andrewh] #1979034
12/30/15 12:23 AM
12/30/15 12:23 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The Magnum of course should be a ported inj with 8 inj and not throttle body inj. Just asking to be sure and are you using the Mopar eng controller ? The Mopar ones would always use a 5 volt signal wire and then one is ground and the key on pull up voltage wire that powers the hall effect up could be from 5 to 12 volts as Mopar has used 5 , 8 , 9 and 12 volts on the key on voltage wire that powers the unit up. I dont remember which yours would have as it would depend on what controller is uses. On the Mopar controllers the crank sensor gives the RPM signal on that type. Actually on the Magnum V/8's you could unhook the dist pickup after the eng is running and it will keep running as once the PCM knows the firing order (from the cam sensor-the dist) it remembers it and keeps going through the same firing order so it does not need to look at the dist pick-up signal until the next start-up. Ron
Re: ms doesn't see the rpm? [Re: Andrewh] #1979108
12/30/15 01:33 AM
12/30/15 01:33 AM
Andrewh Offline OP
Andrewh  Offline OP
I don't know the size of the resistor, but painless used one too. it is already wired in. I clipped the wiring with it still intact.
I will double check but it seems correct.
383 man, this is not quite stock anymore.
the engine and injectors and throttle body are stock.
it is using gm sensors for temp the stock tps, but the distributor has been modified with that shutter wheel and sensor.
it was running an aftermarket efi setup and I am replacing it with another efi setup, just trying to figure out why it won't get a signal.
Re: ms doesn't see the rpm? [Re: Andrewh] #1979129
12/30/15 02:01 AM
12/30/15 02:01 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Not sure if this is what you need. I used one of these to pick up an rpm signal for the digital tack I used with the 5.7 in my 55 pick up. I picked the signal up off of one of the injector trigger wires. Should work on your set up.
http://www.msdignition.com/Products/Accessories/Tach_Adapters/8918_-_Tach_Signal_GMR_Pickup.aspx
Re: ms doesn't see the rpm? [Re: Andrewh] #1979181
12/30/15 05:04 AM
12/30/15 05:04 AM
Andrewh Offline OP
Andrewh  Offline OP
not sure that would help. it isn't firing the injectors on crank as far as I can tell because it isn't getting a cam signal to fire them at all.
Re: ms doesn't see the rpm? [Re: Andrewh] #1979186
12/30/15 05:47 AM
12/30/15 05:47 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Gotch ya. I have not fooled with the aftermarket EFI stuff much at all. All my years were at the Dodge dealer. Thought it may help if you were using mainly factory Mopar setup. Sounds like some of these guys have messed with it. Good luck to you. Ron
Re: ms doesn't see the rpm? [Re: Andrewh] #1979362
12/30/15 03:55 PM
12/30/15 03:55 PM
Andrewh Offline OP
Andrewh  Offline OP
goldduster318- I checked and the resistor is wired like yours.
with the computer unplugged, I get 2.17 ohms on the 20k scale. So 2170 ohms between the two outer pins.
.3 up each line to the connector. so I think I am good there.
problem is, I am not sure what settings to put in the tuner studio for this setup.
Re: ms doesn't see the rpm? [Re: Andrewh] #1980554
12/31/15 08:32 PM
12/31/15 08:32 PM
Andrewh Offline OP
Andrewh  Offline OP
for those of you that have a running megasquirt with ignition, can you tell me if your sensing lines read full voltage or just partial?
I haven't been able to get a response today from diy, so I guess they are closed for the holidays. but since I only get full voltage when I disconnect the ecu, I am begining to thing something is wrong with the box I got.
Re: ms doesn't see the rpm? [Re: Andrewh] #1981848
01/02/16 11:27 AM
01/02/16 11:27 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Andrew are you on Facebook? There is a Megasquirt group that I believe is hosted by DIY. There is some decent help on there a lot of it from DIY Employess and other folks from around the world.
I am using a crank trigger on mine so I am not going to be much help. I use a 36-1 wheel and a Jeep cam sensor on my 360.
68 Barracuda Formula S 340
Re: ms doesn't see the rpm? [Re: Andrewh] #1981972
01/02/16 02:51 PM
01/02/16 02:51 PM
Andrewh Offline OP
Andrewh  Offline OP
no, not on facebook.
but I did join the msextra forum.
they decided that the jumpers were wrong based on the current manuals.
Unfortunatly I broke some pins changing the jumpers so now am stuck till I can get replacments or a new board.
Re: ms doesn't see the rpm? [Re: Andrewh] #1982587
01/03/16 11:13 AM
01/03/16 11:13 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Hate to hear that! Good luck!
Re: ms doesn't see the rpm? [Re: Andrewh] #1985228
01/06/16 10:57 PM
01/06/16 10:57 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Any Luck?
Re: ms doesn't see the rpm? [Re: Andrewh] #1985283
01/07/16 12:02 AM
01/07/16 12:02 AM
Andrewh Offline OP
Andrewh  Offline OP
I got a partnumber from diy on monday for the replacement pins. Got it ordered from mouser same day. They delievered it yesterday, and I was able to replace the pins today.
Tested and got 5 volts now out of the sensor line as expected.
I could see rpm's on the tuner studio during cranking.
So progress. Now I have to see where the timing is. but probably won't get to it till this weekend.
Thanks for the help.
Man this has been a pain. It almost makes me wish I had spent the extra for ez efi instead.
Re: ms doesn't see the rpm? [Re: Andrewh] #1985869
01/07/16 09:51 PM
01/07/16 09:51 PM
Lake Orion, MI
Lake Orion, MI
Shame it's been so hard for you. I spent the bucks on the MS3 Pro...doesn't have any jumpers to set...all software. I had totally forgotten about that on the earlier/less expensive versions.
Re: ms doesn't see the rpm? [Re: Andrewh] #1985873
01/07/16 10:02 PM
01/07/16 10:02 PM
Andrewh Offline OP
Andrewh  Offline OP
yeah, that nickle and dimes it everytime. the upgrade to ms3 was over 100 bucks closer to 200.
put me half way to the ez efi.
But ez might not work with my spark control. so I figured I was better off with ms.
was never going to use the extra features on ms3, but had I known it was easier to wire I might have gone that route too.
eh, live and learn and hope to never have to do it again.
