Re: Billet water neck w/oring
[Re: minivan]
#1981140
01/01/16 03:37 PM
01/01/16 03:37 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
TY, actually looking for the housing that swivels....I have seen the info on here before..
[Re: minivan]
#1981172
01/01/16 04:09 PM
01/01/16 04:09 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Try google this "big block chrysler swiveling water housing" you should get like 10 different ones. Keep away from chromed ones i found they distort, polished is good.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: minivan]
#1981583
01/01/16 10:53 PM
01/01/16 10:53 PM
Posts: 277 MN
Willie68coronet
MN
My chrome housing started finally leaking this past summer. I got the Napa water neck for $6 and change and used a pink Superformance gasket with it on my aluminum mopar pump housing. No sealant, no leaks.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: minivan]
#1982355
01/02/16 11:14 PM
01/02/16 11:14 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Be carefull with steel and aluminum mix. The o ring groove/dissimilar metals action will pitt the housing and will eventually leak
The little old lady from Pasadena is back!
[Re: minivan]
#1982397
01/02/16 11:50 PM
01/02/16 11:50 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I bought the billet one from Mancini and a Superformance gasket and have ZERO leaks. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: a12rag]
#1983160
01/04/16 12:10 AM
01/04/16 12:10 AM
minivan
Eugene, Oregon
Get the one from Terrys auto lab ... www.terrysautolab.com I used this on my 360 and no leaks at all after 4yrs !!! To me, it is worth the $$$$ . . . That's the one I was looking for.. TY A12...
[Re: fourgearsavoy]
#1983161
01/04/16 12:11 AM
01/04/16 12:11 AM
minivan
Eugene, Oregon
I bought the billet one from Mancini and a Superformance gasket and have ZERO leaks. Gus Which Superperfomance gasket is everyone using?? 090 dura cork or the 047 synthetic??
[Re: minivan]
#1983165
01/04/16 12:16 AM
01/04/16 12:16 AM
Posts: 277 MN
Willie68coronet
MN
I got the synthetic one and it seals perfectly on the aluminum napa neck and mp housing. The thicker one is for a not so flat surface I think.
[Re: minivan]
#1983229
01/04/16 01:41 AM
01/04/16 01:41 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Which Superperfomance gasket is everyone using?? 090 dura cork or the 047 synthetic?? [/quote] Just ask Greg at SUPERPERFORMANCE.
[Re: Willie68coronet]
#1984485
01/05/16 10:00 PM
01/05/16 10:00 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I got the synthetic one and it seals perfectly on the aluminum napa neck and mp housing. The thicker one is for a not so flat surface I think. That would be correct and thanks for your support willie! I have even used the chromed pot metal housings with our MP-15 gasket without issues. HOWEVER...... the housing was milled flat. Even brand new they are warped beyond belief
[Re: minivan]
#1987432
01/10/16 10:37 AM
01/10/16 10:37 AM
Posts: 277 Palmyra, NY
63stabamatic
Palmyra, NY
Got this Aluminium one off e-bag, no leaks.
http://www.ebay.com/itm/MOPAR-DODGE-273-440-SOLID-ALUMINUM-WATER-PUMP-THERMOSTAT-HOUSING-INLET-NECK-/400753566922?hash=item5d4ec624ca:g:GMgAAOSwcnpToeAr&vxp=mtrvv
