oil pressure problem #1981738
01/02/16 01:58 AM
01/02/16 01:58 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Well I found my oil pressure problem. LOL
Have to have some fun with the outcome of a bad situation.
Re: oil pressure problem [Re: Bigbeep] #1981747
01/02/16 02:19 AM
01/02/16 02:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well that pan it trash.. how about the headers..
what else did you tear up.. by the way.. thats a
BIG wheelie
wave
Re: oil pressure problem [Re: Bigbeep] #1981757
01/02/16 02:35 AM
01/02/16 02:35 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Well, the pic is a keeper. Hope the car didn't get hurt too bad.
[image][/image]
Re: oil pressure problem [Re: Bigbeep] #1981766
01/02/16 02:53 AM
01/02/16 02:53 AM
baldwinsville new york
a493demon Online content
a493demon  Online Content
On the MFen bumper lol
Re: oil pressure problem [Re: Bigbeep] #1981768
01/02/16 02:55 AM
01/02/16 02:55 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Headers are fine. Lots of little things got damaged. Rear valance, inner fenderwells both are tweaked, hood got cracked where it flexed and hit the fuel line into the barrel valve, front valance flexed and bent, knocked one of the headlights out of the adjusters, header panel slipped out of place as all the dzus fasteners up front connect to it. The worst things are the pan, frame rail on the passenger side got bent upward along with the strut bar on that side, idler arm mount got bent upwards as well.
Was planning on back halfing it with a 4 link and a good set of wheelie bars this winter to address these big dumb wheelies. Been pulling timing at the hit, but obviously I ramped it back in too soon with the mineshaft air we had at the Halloween classic. That wheelie was the first time trial on the sunday warm up race.
Now I think I will be doing both ends of the car this winter if the money holds out. Beep
Re: oil pressure problem [Re: sgcuda] #1981773
01/02/16 03:00 AM
01/02/16 03:00 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
That's all those big wheelies are good for,......Pictures!
As for the car, its fixable. Not cheap, but fixable. I think it will be the old racers adage now. Fix it faster, better, safer. Beep
Re: oil pressure problem [Re: Bigbeep] #1981778
01/02/16 03:12 AM
01/02/16 03:12 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Glad I'm not a wheelie type of guy. If my car does wheelies I fix it before it cost me money. Usually going faster in the process.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: oil pressure problem [Re: pittsburghracer] #1981807
01/02/16 04:57 AM
01/02/16 04:57 AM
One of the comments I heard at one of the old Mopar Drag race seminars made by one of the Mopar chassis gurus was that if the front tars are off the ground, no matter how high, all of the cars weight is on the hind tars work grin I look for 1/2 inch off the ground on the front tires for a short distance, maybe a tiny bit higher but not much twocents
I'm sorry you damaged your car that bad shruggy My current E body Cuda carrys the front tires about three inches off for several feet,less than 60 ft., and then puts them back down, it is a lot easier to steer that way whistling grin
Re: oil pressure problem [Re: Bigbeep] #1981942
01/02/16 01:53 PM
01/02/16 01:53 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Tough luck John nice wheelie though. Get back together see you at the track
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: oil pressure problem [Re: Bigbeep] #1982007
01/02/16 03:35 PM
01/02/16 03:35 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Bad luck..........Not that it matters, but probably should have been putting timing IN instead of taking it out. Wheelie like that is caused by zero wheel speed and a dead hooked tire, rotating pinion around ring gear
Re: oil pressure problem [Re: Monte_Smith] #1982113
01/02/16 04:49 PM
01/02/16 04:49 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Yeah in this pic I came down good, with power on!
I told my buddy Dave "I hope they got that pic. Because I don't want to do it again!"
Later it dead hooked and wasn't going straight so it HAD to come down WITHOUT full power. Wheelie bars came next.
Don
Re: oil pressure problem [Re: cudadon] #1982114
01/02/16 04:52 PM
01/02/16 04:52 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
much better!
Don
Re: oil pressure problem [Re: Bigbeep] #1982131
01/02/16 05:45 PM
01/02/16 05:45 PM
sgcuda Offline
sgcuda  Offline
Uh...Beep, why are you selling those red wheelie bars? Don't you think you might be able to use them? They look good with your headlights.
[image][/image]
Re: oil pressure problem [Re: Bigbeep] #1982145
01/02/16 06:05 PM
01/02/16 06:05 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I've got a few of those oil pans,changed out 3 in 3 weeks , finally got rid of the 90/10 shocks , went to stock Monro which keeps the wheelies manageable.
Re: oil pressure problem [Re: Bigbeep] #1982195
01/02/16 07:15 PM
01/02/16 07:15 PM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
John, Monte is right keep it from dead hooking ! G78 14 bias plys should do it. LOL. I just ordered mine from Coker, I sprung for the red lines !! up drive
Re: oil pressure problem [Re: Bigbeep] #1982214
01/02/16 08:11 PM
01/02/16 08:11 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I've given my pan a beating too but mine was repairable. I fitted some pan saving sacrificial anodes to the K frame. So far they're working well.
Re: oil pressure problem [Re: sgcuda] #1982261
01/02/16 09:39 PM
01/02/16 09:39 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
That's what I was thinking, looks like they should've been on the car. LOL
Re: oil pressure problem [Re: sgcuda] #1982348
01/02/16 11:09 PM
01/02/16 11:09 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
They look real sweet with the headlights. Problem is the caltracs don't care for them too much. Car unloads tire immediately then will porpoise till I lift. Very hard on the tranny. They were actually at the trailer for sale when that wheelstand happened. Beep
Re: oil pressure problem [Re: Bigbeep] #1982445
01/03/16 12:31 AM
01/03/16 12:31 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
. Went threw the same problem wheel stand cost me a lot of Money. Smh
