Stealth Heads #198207
01/19/09 05:18 PM
01/19/09 05:18 PM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Lets start off by,I know there have been other posts. I went back to read up on these heads and after 8 pages, I could't take it anymore. Please leave the politics out of this post. All I'm asking for is, did the keeper, gasket, and dowel problems get corrected? Thanks to ALL for help on my last post. Any part #s for the head gaskets? Can I use the new metal shim gaskets I have with alumium heads? Please send me an email if you have an up date on these heads.
dodgooo@aol.com
Stand behind your word
Re: Stealth Heads [Re: Dodge] #198208
01/19/09 07:02 PM
01/19/09 07:02 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Valve lock/retainer issue was solved long ago. I heard after their first batch of heads, the chamber was made a little smaller to not have the overhang issue. Worst case scenario you have to use the ROL gaskets source sells.
Re: Stealth Heads [Re: Dodge] #198209
01/19/09 07:09 PM
01/19/09 07:09 PM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Thanks for your help once again DaytonaTurbo. Terry Dodge
