Radiator Question? #1981613
01/01/16 11:44 PM
01/01/16 11:44 PM
68gtx Offline OP
68gtx  Offline OP
I sent out the radiator for my 68 GTX to be recored. They did a nice job looks fine but it doesn't fit the same? It looks like I will have to squeeze the brackets in a bit and it seems set slightly lower than before? Is it possible the brackets were soldered in the wrong spot? I will be able to get it in but it just doesn't fit the same? Anyone else ever run into this? Thanks Larry J
Re: Radiator Question? [Re: 68gtx] #1981650
01/02/16 12:14 AM
01/02/16 12:14 AM
N.E. OHIO
P
polara426 Offline
polara426  Offline
P
N.E. OHIO
Yes I had one recored on a 64 b body that I had to have the brackets moved on the core was to close to the fan. I think it is critical where they solder the cor in the brackets.
Re: Radiator Question? [Re: 68gtx] #1981673
01/02/16 12:33 AM
01/02/16 12:33 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Glen Ray radiator is the only place that you can trust doing that.
Re: Radiator Question? [Re: polara426] #1981674
01/02/16 12:34 AM
01/02/16 12:34 AM
IN
ahy Offline
ahy  Offline
IN
I would drill out those holes so it is not in a bind and use large washer head bolts (like OE I think?)... or get it re-done if it is too far off.
Installing it in a bind may cause problems like leaks down the road.
Re: Radiator Question? [Re: 68gtx] #1981702
01/02/16 12:57 AM
01/02/16 12:57 AM
68gtx Offline OP
68gtx  Offline OP
Thanks We had to grind the the upper bolt holes slightly. With the OE bolts you cannot see it so I'm good with it. Thanks Larry J
