I Need To Do Some Research On VIN #1981312
01/01/16 06:59 PM
01/01/16 06:59 PM
MR_P_BODY Offline OP
I pulled the dash out of the P-Body and pitched it
when I built it as a race car.. never thought about
the VIN tag on the dash... well now I'd like to use
it on the street.. I am gonna have to talk with the
local police to see if I can have one made being I
have the title on it... anyone have any ideas
thanks.. Happy New Year to all of ya
wave
Re: I Need To Do Some Research On VIN [Re: MR_P_BODY] #1981318
01/01/16 07:06 PM
01/01/16 07:06 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
I work for Vehicle Fleet co. and many times we have states come out to put reconstructed vehicle VIN #'s on units or State assigned VIN#'s
There should be more then just the Dash VIN pate on your ride.
Check the package tray, radiator support , fire wall or frame rail if you have any factory rails left thumbs
Switched to the dark side...
Re: I Need To Do Some Research On VIN [Re: MR_P_BODY] #1981320
01/01/16 07:10 PM
01/01/16 07:10 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
Try this , looks easy in your state
http://www.michigan.gov/sos/0,4670,7-127-1585_1587_1588-25476--,00.html
Re: I Need To Do Some Research On VIN [Re: MR_P_BODY] #1981323
01/01/16 07:11 PM
01/01/16 07:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
wave
There are some stamped numbers in secret areas that correspond with either the vin or engine serial number, I know that those numbers are stamped in the trunk drip rail on the driverside under or close to where the weatherstripping is, I don't know if that is anything that will help or not.
Re: I Need To Do Some Research On VIN [Re: JSR1485] #1981328
01/01/16 07:15 PM
01/01/16 07:15 PM
I have none of that left.. if I recall there was a vin
on the back hatch area on the body(under the rubber seal)
I would have to look.. but I need a dash VIN for quick
looks.. if I decided to build it for DW
wave
Re: I Need To Do Some Research On VIN [Re: MR_P_BODY] #1981413
01/01/16 08:22 PM
01/01/16 08:22 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Doesn't the title have the VIN on it?
2011 Drag Pak Challenger
Re: I Need To Do Some Research On VIN [Re: rickseeman] #1981418
01/01/16 08:29 PM
01/01/16 08:29 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Ohio titles do, I think the issue is trying to prove that title belongs to that vehicle.
