Elephant Ears...where to buy? #1980804
01/01/16 01:17 AM
01/01/16 01:17 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Anybody know of a supplier for old school bb/hemi a body two piece elephant ears? Ive been digging online and can come up with much. I see some from comp engineering, not sure how well they work. Not interested in a big motor plate.
Re: Elephant Ears...where to buy? [Re: Hot 340] #1980823
01/01/16 01:51 AM
01/01/16 01:51 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i have Comp Engineering motor plates, they fit well but if i had more HP i'd probably look for thicker ones. I like CE's plates as they allow plenty of room top mount things like Alternators, vac pumps, coils & relays.
Re: Elephant Ears...where to buy? [Re: rebel] #1980836
01/01/16 02:02 AM
01/01/16 02:02 AM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
Andy makes a nice one. cool
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Elephant Ears...where to buy? [Re: hemi-itis] #1980844
01/01/16 02:09 AM
01/01/16 02:09 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Andys is ok but it's 1 piece & doesn't allow for mounting accessories off it.
Re: Elephant Ears...where to buy? [Re: Hot 340] #1980883
01/01/16 03:18 AM
01/01/16 03:18 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I always thought elephant ears were often just full size plates that got widdled down as each owner saw fit for his application. work
Re: Elephant Ears...where to buy? [Re: jcc] #1980887
01/01/16 03:28 AM
01/01/16 03:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I never liked the ears... they would always come
loose being that they moved being 2 separate plates..
they hinged on the bolts
wave
Re: Elephant Ears...where to buy? [Re: MR_P_BODY] #1980895
01/01/16 03:50 AM
01/01/16 03:50 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
wave
Totally agree!
Re: Elephant Ears...where to buy? [Re: markz528] #1980906
01/01/16 04:17 AM
01/01/16 04:17 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
wave
Totally agree!
I don't know about your racecar maintenance but we do regular "spanner checks", & constantly check things for tightness. maybe it's your plate design, but mine fit in between the chassis rails. once they've been installed & tightened, there's nowhere for them to go anywhere even if they did somehow get loose.
Re: Elephant Ears...where to buy? [Re: MR_P_BODY] #1980955
01/01/16 11:32 AM
01/01/16 11:32 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
wave
I agree Mr. P.
Re: Elephant Ears...where to buy? [Re: MR_P_BODY] #1980957
01/01/16 11:50 AM
01/01/16 11:50 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
wave
Over the years i have heard that same complaint from other people, had one fellow tell me that once he added engine limiters for the fore and aft movement and that helped the problem alot. shruggy
Re: Elephant Ears...where to buy? [Re: Hot 340] #1980959
01/01/16 11:55 AM
01/01/16 11:55 AM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
Sent you a PM for what you are looking for
Re: Elephant Ears...where to buy? [Re: Hot 340] #1980963
01/01/16 12:01 PM
01/01/16 12:01 PM
Maryland
gofastboater Offline
Maryland
Years ago I found a pattern for them. I have used it to make many sets. My latest set I made out of 1/4" SS and had them polished. I could possibly send the pattern to you.
Re: Elephant Ears...where to buy? [Re: Hot 340] #1980979
01/01/16 12:34 PM
01/01/16 12:34 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Try Mancini and Competition Engineering,we custom build the ears and full engine plates
Re: Elephant Ears...where to buy? [Re: B G Racing] #1981086
01/01/16 02:43 PM
01/01/16 02:43 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I have a set that I bought years ago and never put a big block in my car. I now have no plans to so they are available.
Re: Elephant Ears...where to buy? [Re: Hot 340] #1981091
01/01/16 02:51 PM
01/01/16 02:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I had a friend that was breaking tailshaft's because the 'ears' were allowing movement so he switched to a full motor plate. The ears that Rebel uses look like they have enough mounting points to do a better job for sure, I actually like that idea for my car as it would eliminate the thickness of the plate which puts the water pump snout only 2.75 inches from my radiator, it's just a street car anyways. I do love my AR-Engineering plate though, it works good and looks really nice.
Re: Elephant Ears...where to buy? [Re: Hot 340] #1981093
01/01/16 02:53 PM
01/01/16 02:53 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
After looking at it more, I might be wrong. Rebel, do your ears go between the block and water pump? Hard to see on my phone.
Re: Elephant Ears...where to buy? [Re: Hot 340] #1981098
01/01/16 02:55 PM
01/01/16 02:55 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My plate
Re: Elephant Ears...where to buy? [Re: ProSport] #1981171
01/01/16 04:07 PM
01/01/16 04:07 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Andys plates not only are nice and heavy duty but they look great too. I will be buying another small and big block one in the near future.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Elephant Ears...where to buy? [Re: Hot 340] #1981179
01/01/16 04:18 PM
01/01/16 04:18 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Two piece mounts will NEVER be as rigid and solid as a one piece plate................doesn't matter if you tighten the bolts after every run
A BBM does not have bolt holes in the bottom of the block to help hold the plate in place, like Chevy motors do, so clamped behind the water pump mounts is it, that's all you got. Gives a scissor effect as MrP says and it always will. The holes are never precision, so they come off and put them back on, they may or may not be in the same place. If you ever need a screwdriver to line them up with chassis.........SOMETHING moved. May not be big deal for many, but the two piece ones do move around
Re: Elephant Ears...where to buy? [Re: Hot 340] #1981198
01/01/16 04:43 PM
01/01/16 04:43 PM
Ohio
lockjaw-express Offline
Ohio
AndyF's plates are the best I have seen or used...it also clears the Jesel belt drive too!
my 2 cents, Mark
