There is absolutely no reason to use a 7.1" rod on a 3.75 stroke unless you are talking about 10,000 rpm.
There is, though, a very good reason to use a 2.200" rod journal, which lets the crank stroke go to 3.90 or 3.91. Then a 6.535 rod will be easy and cheap and most of the major manufacturers of forged pistons have lightweight slugs as shelf stock that will fill out the rest of the setup.
Or use the 3.75 stroke, a decent set of 440 length rods (those pistons are really light so even the stockers will probably do) and the KB pistons mentioned above.
Check out the last several years of EngineMasters and you'll see that many of the winning combos used really short rods compared to the strokes, and they made the most average power and torque between 3000 and say 6500 rpm.
I used to be a long rod believer but time and again it has proven to be incorrect for street engines.
R.
