2000 Jeep Grand Cherokee starting issue #1973460
12/20/15 08:51 PM
12/20/15 08:51 PM
70duster340 Offline OP
Having some issues with starting the Jeep. Dash lights go very dim, and it cranks slowly. I have replaced the battery, cleaned the battery cables, and had to replace the starter, since one of the terminals broke off. I just bought a salvage yard starter, but it tested good. The battery is new, and should easily be enough to spin the motor over quickly. Could the alternator be about to give up the ghost?
Re: 2000 Jeep Grand Cherokee starting issue [Re: 70duster340] #1973573
12/21/15 01:03 AM
12/21/15 01:03 AM
Anybody?
Re: 2000 Jeep Grand Cherokee starting issue [Re: 70duster340] #1973579
12/21/15 01:17 AM
12/21/15 01:17 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Take the Jeep to the local major parts store and have them check out the starting and charging system. Most do it for free.
Re: 2000 Jeep Grand Cherokee starting issue [Re: 70duster340] #1973873
12/21/15 03:47 PM
12/21/15 03:47 PM
I'll give that a try, thanks.
Re: 2000 Jeep Grand Cherokee starting issue [Re: 70duster340] #1974297
12/22/15 02:25 AM
12/22/15 02:25 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Check your grounds. A quick way to check is with a set of good jumper cables. Hook both leads on the same end to the negative post of the battery and then hook one of the other leads to the engine block and the other to the body, such as the radiator core support. Then try cranking the vehicle. if it cranks normal you have a ground issue. I see a lot of Jeeps with negative battery terminals bad with corrosion between the wires and the terminal. Hope this helps.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2000 Jeep Grand Cherokee starting issue [Re: 70duster340] #1977196
12/27/15 04:01 PM
12/27/15 04:01 PM
I will give that a try, and thanks a bunch!!!
Re: 2000 Jeep Grand Cherokee starting issue [Re: 70duster340] #1980137
12/31/15 02:33 PM
12/31/15 02:33 PM
I believe the Jeep is suffering from a bad ground. Given the age and miles, I would like to replace the battery cables. Is this a big job?
Re: 2000 Jeep Grand Cherokee starting issue [Re: 70duster340] #1980373
12/31/15 05:41 PM
12/31/15 05:41 PM
Anybody?
Re: 2000 Jeep Grand Cherokee starting issue [Re: 70duster340] #1980454
12/31/15 06:49 PM
12/31/15 06:49 PM
Grand Prairie,Texas
Grand Prairie,Texas
It's easier than a starter swap. Just eyeball the cables to see what you need to do. Just remember to hook the battery up last. biggrin
Re: 2000 Jeep Grand Cherokee starting issue [Re: 70duster340] #1980551
12/31/15 08:30 PM
12/31/15 08:30 PM
OK and, thank you!
Re: 2000 Jeep Grand Cherokee starting issue [Re: stumpy] #1980559
12/31/15 08:37 PM
12/31/15 08:37 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Where's excitement in that? laugh2
Re: 2000 Jeep Grand Cherokee starting issue [Re: 70duster340] #1982371
01/02/16 11:24 PM
01/02/16 11:24 PM
Yeah, I need a little excitement in my life.😨
