Re: Front Snout bars...........
[Re: camdog440]
#1980005
12/31/15 08:35 AM
12/31/15 08:35 AM
Posts: 10,038 MN
JERICOGTX
MN
How the front bars are done on my Road Runner. Tied into the shock tower and the front motor plate brackets.
69 GTX
68 Road Runner
[Re: dvw]
#1980222
12/31/15 03:48 PM
12/31/15 03:48 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Fabbed inner fender panels and finished result [img:left] [/img] Yet further evidence that Lickity Split is the sexiest drag car on the planet....
[Re: dvw]
#1980989
01/01/16 12:47 PM
01/01/16 12:47 PM
Posts: 4,072 Mo.
racerx
Mo.
The other side of the firewall. In the above pics the piece cut out with a large holesaw for access has been welded back in. Doug Doug....is you cage mild steel or chromely? If mild steel what size/brand of wire you using?
[Re: racerx]
#1981056
01/01/16 02:19 PM
01/01/16 02:19 PM
Posts: 2,926 A shed in England
Tig
A shed in England
We did ours similar to Camdogs, best photo I have is this. Car is at the bodyshop so cant take pics at the moment. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: racerx]
#1981303
01/01/16 06:49 PM
01/01/16 06:49 PM
Posts: 9,860 MI, usa
dvw
MI, usa
The other side of the firewall. In the above pics the piece cut out with a large holesaw for access has been welded back in. Doug Doug....is you cage mild steel or chromely? If mild steel what size/brand of wire you using? Chrome Moly. All is tigged except the snout bars to the front frame.They were done with standard ER70S .030" mig wire. Doug
