Interior Paint ? #198004
01/19/09 12:09 PM
01/19/09 12:09 PM
Westphalia, Meeeeeshigan
MIRADAMANia Offline OP
I want to paint the steering column, dash frame and other metal interior parts on my 71 Charger. What have you had good luck with? Also there is some kind of glue dried onto the dash frame where a previous owner tried to cover up a cracked dash pad. Any suggestions for removing it before I paint it?
Re: Interior Paint ? [Re: MIRADAMANia] #198005
01/19/09 08:28 PM
01/19/09 08:28 PM
Re: Interior Paint ? [Re: MIRADAMANia] #198006
01/19/09 09:23 PM
01/19/09 09:23 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I used SEM trim paint (black) I think it is a lacquor base looked very good on my 73 Road Runner. I did remove the dash blast it epoxy and k36 before I sprayed it to prevent fisheyes from years of armor all. Good luck
Re: Interior Paint ? [Re: MIRADAMANia] #198007
01/19/09 10:05 PM
01/19/09 10:05 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
SEM makes Color Coat in lots of colors. You need to clean the parts very well and use their adhesion promoter. Follow the instructions on the can for a perfect job. You can use it on metal if you use a etching primer first.
Before
After
Re: Interior Paint ? [Re: Lefty] #198008
01/19/09 11:36 PM
01/19/09 11:36 PM
Ky.
dart67 Offline
dart67  Offline
Ky.
Lefty, man that is great work!
