Re: My Junk Updates... [Re: camdog440] #197910
01/19/09 06:02 PM
01/19/09 06:02 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
Re: My Junk Updates... [Re: joshking440] #197911
01/19/09 06:33 PM
01/19/09 06:33 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
now that that is over how about some build info with the pics.
1972 Duster 496 Kilpatrick prepped B-1 lowdeck, Procharged, FAST XFI injection on e-85
weight of car?
who's stroker kit?
what pistons?rings/gap?
how is the block prepped?
what # procharger and OD will you use?
what LB injectors and make of?
Re: My Junk Updates... [Re: blownzoom440] #197912
01/19/09 07:10 PM
01/19/09 07:10 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
The Block is a Dunnuck one off high performance 400 1971 230 casting.
Block is 1/2 filled
BCR Girdle and Caps
Bill Miller Rods
Eagle Crank
Diamond Pistons with ceramic coated tops and moly coated skirts
tool steel pins
Little port work on the heads
Titanium retainers
Comp 947 springs
Comp Custom Grind Cam .715 lift [Email]248@.50[/Email] 114 centerline
Car weighs around 3200 lbs
28x13.50 MT Et Streets as you can see...
The rest of the details are still undecided...
Re: My Junk Updates... [Re: joshking440] #197913
01/19/09 07:26 PM
01/19/09 07:26 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Looking good and a nice looking ride to put it in.
Re: My Junk Updates... [Re: dartman366] #197914
01/19/09 07:35 PM
01/19/09 07:35 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
I will be glad once I get it all mocked up so I can get the thing off to paint...
What do you fellow moparts guys think....
All Black with a White Stripe or....Similar Blue with gloss black hood and tops of fenders and cowl and door like the originals came???
Re: My Junk Updates... [Re: joshking440] #197915
01/19/09 07:38 PM
01/19/09 07:38 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
blue with white 340 stripe and black hood
1.39 9.85 - 137 mph
Re: My Junk Updates... [Re: joshking440] #197916
01/19/09 07:56 PM
01/19/09 07:56 PM
ELYRIA,OH
ELYRIA,OH
sounds like a good foundation.
do you have more duration on the exhaust?mine is a 260/269 at .050.112 lsa.i would have liked more lsa but it worked out fine.
Re: My Junk Updates... [Re: joshking440] #197917
01/19/09 08:03 PM
01/19/09 08:03 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello Joshking 440,
That's some fair lift to only have 248 at 50. Pressurized pump gasser can I assume? What et are you shooting for?
Damon
Re: My Junk Updates... [Re: mopardamo] #197918
01/19/09 08:21 PM
01/19/09 08:21 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Josh,
Keep up the great work! Nice to see that it's coming together!
On the color choice,I am partial to blue,but their seems to be a lot of blue 70-74 a-bodies around.I think black would stand out more.(Good luck keeping it clean though).
Keep us updated
Keith
Re: My Junk Updates... [Re: Dunnuck Racing] #197919
01/19/09 08:41 PM
01/19/09 08:41 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Are you conserned about splitting a cylinder wall with that much power??? I would be..
Nice build BTW...
Re: My Junk Updates... [Re: Bob_Coomer] #197920
01/19/09 08:55 PM
01/19/09 08:55 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
Im concerned with splitting a lot of things...cylinders, cranks, rods, axles, transmissions...
I do know that the December Hot Rod has a procharged lowdeck in it and they made 1400 horse and I know for a fact that that motor saw TONS of dyno pulls...the only problem they had was cap walk which was never mentioned. I hope I got rid of that problem with the girdle and aluminum rods and caps...
The supercharger store has made 1700hp with a stock block, but they broke a rod when the motor detonated because of an fuel injection issue...
Im going to try to make 1000 at the rear tires once, then tune it back. Hopefully she holds...
Re: My Junk Updates... [Re: mopardamo] #197921
01/19/09 08:56 PM
01/19/09 08:56 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
Well close, E-85 with some boost in there somewhere. I dont have a ET that I am shooting for. I would like to see a 8 second run but Im not sure if that is going to happen on those tires...
Re: My Junk Updates... [Re: joshking440] #197922
01/19/09 09:01 PM
01/19/09 09:01 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Im not knocking your build at all, sounds very nice. But...
sounds like you have a ton of money in just the block, why didnt you just get a aftermarket Iron one? You would half to have near what a new one would cost.
BTW
I would love to build a Big inch Mopar on boost...I will be looking forward to your progress.
Re: My Junk Updates... [Re: Bob_Coomer] #197923
01/19/09 09:19 PM
01/19/09 09:19 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
Trust me I understand where you are coming from...
This all started as a nice little 500" budget build and then
I already had rods and crank. only needed pistons...then the girdle....I looked at getting a aftermarket lowdeck from Indy, but $4500 just didnt fit in the budget, and to buy more rods and another crank for an aftermarket steel block...
So as the build progressed I ended up with a very budget minded grenade that may just never go off...
Re: My Junk Updates... [Re: joshking440] #197924
01/19/09 09:21 PM
01/19/09 09:21 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
Your "junk" looks better than my "nice stuff"
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: My Junk Updates... [Re: fasteddie] #197925
01/19/09 09:29 PM
01/19/09 09:29 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
Its all junk until it runs....then its junk again when we break it...I bet your stuff runs
Re: My Junk Updates... [Re: joshking440] #197926
01/19/09 09:42 PM
01/19/09 09:42 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
those tires are more than capabel of 8 sec runs.. They just wont last that long, the sidewalls will be gone long before the tread
....BAD A$$ STREET CAR.....
Re: My Junk Updates... [Re: n20mstr] #197927
01/19/09 10:32 PM
01/19/09 10:32 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
I just hope I am capable...I cant afford to build this car and buy new underwear all the time as well
Re: My Junk Updates... [Re: joshking440] #197928
02/14/09 07:37 PM
02/14/09 07:37 PM
bcrproducts Offline
super gas
bcrproducts  Offline
super gas
Hi Josh
Nice to see what those caps went into. Great looking build. Send pics to my email address so I can post them----Greg
