collector size for 468 sbm #1978603
12/29/15 03:09 PM
12/29/15 03:09 PM
Edmonton Alberta, Canada
R3DART Offline OP
R3DART  Offline OP
Hello folks.
I am looking for some opinions on whether I should have my headers modified for a bigger collector.
I have the 1 7/8 TTI with 3" collector for W2 heads
From what I understand, the new version of these headers come with 3.5" collector.
So my question is, do you think it's worth it to modify the collector and destroy the coating?
How much performance am I leaving on the table by staying with the 3"?
The combo is as follows;
468 ci
Indy 245 cnc
Pump gas
Solid roller
1050 dominator
Car is 3000 lb (with me) abody
727
5200 stall
Dana 60- 3:91
Thanks in advance guys.
Re: collector size for 468 sbm [Re: R3DART] #1978607
12/29/15 03:15 PM
12/29/15 03:15 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I don't think the ends justify the means. Is it a maximum effort combo? I don't think you'll see a large enough gain, especially if it's an NA build
Re: collector size for 468 sbm [Re: R3DART] #1978612
12/29/15 03:21 PM
12/29/15 03:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By R3DART
Hello folks.
468 ci
Indy 245 cnc
Pump gas
Solid roller
1050 dominator
727
5200 stall
Dana 60- 3:91
What RPM do you turn... but I would think a 1 7/8 pri
and a 3" collector are small... if you want you can
PM me and I'll run your engine specs through my header
program for the proper headers
wave
Re: collector size for 468 sbm [Re: SpareParts] #1978684
12/29/15 04:46 PM
12/29/15 04:46 PM
R3DART Offline OP
R3DART  Offline OP
Thanks for the response.
SpareParts; Not really a max effort although I plan to keep tweaking as I go.
Now would be the time for me to do it (change collector) if it made sense.
But by the time I get someone to do it and have them recoated, it's not going to be pocket change....
Mr P, I will pm you some specs.
I am curious on this, probably no point in fooling with collectors if tube size is not ideal as well.
If that turns out to be the case, it makes the decision easier.
Re: collector size for 468 sbm [Re: R3DART] #1978690
12/29/15 04:52 PM
12/29/15 04:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
After you PM me I'll send you what I need.. as for what
you have now it might be worth selling them OR changing
the collector.. that would be your choice.. I use a 3.5"
collector on most anything(either big cubes or high rpm)
wave
Re: collector size for 468 sbm [Re: MR_P_BODY] #1978708
12/29/15 05:19 PM
12/29/15 05:19 PM
R3DART Offline OP
R3DART  Offline OP
Pm sent
Re: collector size for 468 sbm [Re: R3DART] #1978712
12/29/15 05:26 PM
12/29/15 05:26 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Can I change my vote? I misread the title and thought it said 428 lol makes a difference to me
Re: collector size for 468 sbm [Re: SpareParts] #1978816
12/29/15 08:03 PM
12/29/15 08:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No-No... change you vote now... LOL
wave
Re: collector size for 468 sbm [Re: MR_P_BODY] #1978919
12/29/15 10:19 PM
12/29/15 10:19 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Easy to slip a schoenfeld 3 1/2" collector over the 3", cut iabout 38" behind the cloverleaf welds and use the slip on /weld up collector for one size larger primary pipe than the one you have, Easy to do, I've done it several times.
WIZE
In Car:
Re: collector size for 468 sbm [Re: MR_P_BODY] #1978980
12/29/15 11:32 PM
12/29/15 11:32 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
wave
Hell I can't read or vote right frown
Re: collector size for 468 sbm [Re: Streetwize] #1979031
12/30/15 12:22 AM
12/30/15 12:22 AM
R3DART Offline OP
R3DART  Offline OP
Thanks.
I wonder how much differnece just the collector will make.
I am interested to see what Mr Pbody's program says. If I need bigger header all around, probably won't bother modifying these, just run them for the season and make a change when the time is right.
Re: collector size for 468 sbm [Re: R3DART] #1979036
12/30/15 12:27 AM
12/30/15 12:27 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I have 2" primaries and 3 1/2" collector on my Indy 454 SB. It works ok 5.66@120 @2775
Re: collector size for 468 sbm [Re: R3DART] #1979041
12/30/15 12:30 AM
12/30/15 12:30 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would want to see 2in/3.5 collector for sure on some thing that big.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: collector size for 468 sbm [Re: R3DART] #1979043
12/30/15 12:32 AM
12/30/15 12:32 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I am going 2 to 2 1/8 to 2 1/4 with a 4 inch collector on my 422.
Re: collector size for 468 sbm [Re: 1967dartgt] #1979072
12/30/15 01:02 AM
12/30/15 01:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I just sent him his numbers.. it calls for 2.027" to
2.152" dia and a collector dia of 3.686"to 3.936"with
a length of 16.1".... thats for a bigger engine than
yours... if you go bigger on dia it also changes the
pri lengths...remember that is a timed length based on
a dia.... all the specs I quoted are OD with a .062 wall
edit
for a 3 step headers your diameters are close enough but
you need to figure the lengths.. the 4" collector is close
enough also... without running numbers
wave
Re: collector size for 468 sbm [Re: R3DART] #1979112
12/30/15 01:38 AM
12/30/15 01:38 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mines a nos motor so short is your friend. Just need to get heat out as fast as you can with no major restrictions. I was running 2 in with 3.5 collectors before.
Re: collector size for 468 sbm [Re: R3DART] #1979221
12/30/15 11:28 AM
12/30/15 11:28 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I'm not looking forward to the day I build bug headers for mine. Should be lots of cuss words involved lol
Re: collector size for 468 sbm [Re: 1967dartgt] #1979233
12/30/15 11:56 AM
12/30/15 11:56 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
Are these something you are building yourself? Or do you have someone lined up to build them?
Re: collector size for 468 sbm [Re: 80arrow] #1979237
12/30/15 12:07 PM
12/30/15 12:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
These are what I built for my 405ci W-9.. three step
1 7/8- 2 -2 1/8
wave
Re: collector size for 468 sbm [Re: MR_P_BODY] #1979251
12/30/15 12:38 PM
12/30/15 12:38 PM
8
80arrow Offline
80arrow  Offline
1 7/8- 2 -2 1/8
wave
Those look awesome. I'm sure I'll have to make my own headers but figured I'd ask about 1967dartgt's set. I really don't want to make a set for my car, lol.
