Re: My Junk Updates...
[Re: camdog440]
#197910
01/19/09 06:02 PM
01/19/09 06:02 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: joshking440]
#197911
01/19/09 06:33 PM
01/19/09 06:33 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
now that that is over how about some build info with the pics. 1972 Duster 496 Kilpatrick prepped B-1 lowdeck, Procharged, FAST XFI injection on e-85 weight of car? who's stroker kit? what pistons?rings/gap? how is the block prepped? what # procharger and OD will you use? what LB injectors and make of?
[Re: mopardamo]
#197918
01/19/09 08:21 PM
01/19/09 08:21 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Josh, Keep up the great work! Nice to see that it's coming together! On the color choice,I am partial to blue,but their seems to be a lot of blue 70-74 a-bodies around.I think black would stand out more.(Good luck keeping it clean though). Keep us updated Keith
[Re: Dunnuck Racing]
#197919
01/19/09 08:41 PM
01/19/09 08:41 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Are you conserned about splitting a cylinder wall with that much power??? I would be.. Nice build BTW...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: joshking440]
#197922
01/19/09 09:01 PM
01/19/09 09:01 PM
Bob_Coomer
Rock Springs
Im concerned with splitting a lot of things...cylinders, cranks, rods, axles, transmissions...
I do know that the December Hot Rod has a procharged lowdeck in it and they made 1400 horse and I know for a fact that that motor saw TONS of dyno pulls...the only problem they had was cap walk which was never mentioned. I hope I got rid of that problem with the girdle and aluminum rods and caps...
The supercharger store has made 1700hp with a stock block, but they broke a rod when the motor detonated because of an fuel injection issue...
Im going to try to make 1000 at the rear tires once, then tune it back. Hopefully she holds...
Im not knocking your build at all, sounds very nice. But... sounds like you have a ton of money in just the block, why didnt you just get a aftermarket Iron one? You would half to have near what a new one would cost.
BTW I would love to build a Big inch Mopar on boost...I will be looking forward to your progress.
[Re: fasteddie]
#197925
01/19/09 09:29 PM
01/19/09 09:29 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
Your "junk" looks better than my "nice stuff"
Its all junk until it runs....then its junk again when we break it...I bet your stuff runs
[Re: joshking440]
#197926
01/19/09 09:42 PM
01/19/09 09:42 PM
Posts: 4,673 On the parachute mount
n20mstr
those tires are more than capabel of 8 sec runs.. They just wont last that long, the sidewalls will be gone long before the tread
....BAD A$$ STREET CAR.....
