Page 8 of 8 1 2 3 4 5 6 7 8
Re: What front-end system system would you go with? [Re: justinp61] #1978820
12/29/15 08:05 PM
12/29/15 08:05 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By justinp61
Originally Posted By sixpackgut
Think its a mustang 2 spindle
His site lists either Wilwood or 2" drop Mustang II. Both spindles use the same brake components.
That would explain it, had Mustang ll stock spindles on my last car( didn't look like those) and had 3 inches between frame and ground. Is the 2" drop for raising or lowering the car?
Re: What front-end system system would you go with? [Re: cudaman1969] #1978838
12/29/15 08:31 PM
12/29/15 08:31 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Lowers the car
Re: What front-end system system would you go with? [Re: racerx] #1978886
12/29/15 09:36 PM
12/29/15 09:36 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Originally Posted By racerx
I've notice on Bob's website that he shows his k-frame front suspension on Rick's challenger and (it could be just the angle of the pic.)
was taken, but how low does this k-member sits?And also I know there's video out there with Rick's challenger using Bobs front suspension on it but I can't seem to find it.
Are you looking for how much clearence from the ground or stance of it?
I'm looking for the clearance from the center of the bar(k-frame) to the ground. As I've said before maybe it's the angle in which the pic. was taken........... wave
5 3/4 inches from ground to the bottom center of the k frame bar with a 26" front tire.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: What front-end system system would you go with? [Re: megajoltman] #1978892
12/29/15 09:41 PM
12/29/15 09:41 PM
Mo.
racerx Offline
racerx  Offline
Mo.
perfect....sir Thaxs up
