Milling 452 casting BB heads - how low can you go??
#197867
01/19/09 10:24 AM
01/19/09 10:24 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Is it possible to safely mill a 452 casting down to 75cc (from 88cc)? Going on a mild street engine that needs a big compresion boost. BTW, I have the 452's already and want to spend as little as possible on this engine. So switching heads is not what I'm looking into right now. Thanks
2 kids and a dog
Re: Milling 452 casting BB heads - how low can you go??
[Re: quickd100]
#197872
01/19/09 02:11 PM
01/19/09 02:11 PM
Posts: 576 Texas
ChevyTS
Texas
60 off the chamber side 74 off the intake side will bring a late 440 from 8.2 to 9.7 perr mopar performance . You will have to shim stock rockers though.
T & K Performance
[Re: HotRodDave]
#197875
01/19/09 04:23 PM
01/19/09 04:23 PM
RapidRobert
My welder wanted to try to weld up the open chambers in a set of my 906's then mill em flat.
[Re: RapidRobert]
#197876
01/19/09 04:30 PM
01/19/09 04:30 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Speed o motive used to do that.
[Re: HotRodDave]
#197877
01/19/09 05:00 PM
01/19/09 05:00 PM
RapidRobert
Thanks for the vote of confidence, I may have him go ahead. He owes me some labor time so I might as well take it out in trade this way
[Re: RapidRobert]
#197878
01/19/09 05:29 PM
01/19/09 05:29 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
There was someone doing that once (in CA I think) I was going to look into it but along come aluminum heads. I once had .110 off a set of 906 made them closed chamber. cracked after a few years up in the bowls ends up my porting left it 1/16th thick and a small crack opened up!
[Re: ChevyTS]
#197881
01/19/09 06:59 PM
01/19/09 06:59 PM
Posts: 75,072 U.S.S.A.
JohnRR
U.S.S.A.
shimming the rockers is not the correct way to make up for aggressive head milling , the shims are for correcting incorrect rocker geometry
[Re: HotRodDave]
#197882
01/19/09 08:40 PM
01/19/09 08:40 PM
Posts: 3,149 Central NC
gch
Central NC
I angle milled my 346 heads to 78cc.I would have gone farther if not for the piston hitting the head.By angle milling instead of flat milling you are removing the most metal from the lower(outside)part of the head.I have no issues with pushrods or intake sealing and did not touch the intake side of the head or the intake itself.
If you didn't need the intake side milled your machinist definately did not angle mill the heads, also when angle milling the bolt heads will not sit flat on the head, if it is angle mille enough then the bolts will not even start in the holes because the bolt can not go straight in. If the intake was not milled you will end up with vacume leaks on the intake to head mateing surface unless you put a ton of silicone or something on it in that case it will leak soon. Doing angle milling the right way is very involved and not cheap.
I'm no engine builder or machinist for that matter.All I can tell you is he angle milled the heads and I have not had to do anything extra or fancy and it all works and fits fine.I have changed intakes on the motor and had no problems with alignment or starting bolt holes.I do seem to remember him saying something about spotfacing the bolt holes.Make any sense He is an excellent engine buider and drag racer as well.
[Re: gch]
#197883
01/19/09 09:10 PM
01/19/09 09:10 PM
Posts: 576 Texas
ChevyTS
Texas
See if you can find out how he milled the heads exactly. That would good info to have. I have angel milled a few sets and it is no easy chore.
T & K Performance
