Tachometer cable
#1978434
12/29/15 09:39 AM
12/29/15 09:39 AM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
I have been looking for tachometer cable between MP distributor and SW #535 gauge. Is there new ones available? GOOGLE has not been my friend so far..
Thanks! Pepe
1970 Plymouth GTX 440-6 1970 Plymouth PPR Cuda 489-4 1971 Plymouth Duster Bad Romance 408-W2-8bbl
Re: Tachometer cable
[Re: ArcticCuda]
#1978453
12/29/15 11:09 AM
12/29/15 11:09 AM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
Doing it all the time. There is plenty of Moroso/Motorola cables, but they don't fit.
[Re: ArcticCuda]
#1978628
12/29/15 03:46 PM
12/29/15 03:46 PM
Posts: 109 Canada
restoracer
Canada
Doing it all the time. There is plenty of Moroso/Motorola cables, but they don't fit. You are probably finding the thread size smaller on the tach end is different from the distributor end right? These are unique as I came across that ,is it for a correct resto of a nostalgia car that you need to use the SW tach ? Otherwise might be easier to change tachs to a more common cable on a moroso or even a Jones tach .
[Re: ArcticCuda]
#1978682
12/29/15 04:44 PM
12/29/15 04:44 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
How long do you need it to be? I've ran into this problem in the past, you need the little adapter for the S.W. tach and the matching cable length with the proper tach end for the adapter I may have one,let me know the length you need and I'll check mine to see if it will be long enough Edited, both of my cables are for the Jones Motorola tachs, sorry I must have sold the other cable with the adpater when I sold the last S.W tach several years ago, CRS disease
[Re: ArcticCuda]
#1978703
12/29/15 05:16 PM
12/29/15 05:16 PM
Posts: 170 renton , washington
perfmachst
renton , washington
hi , I have same setup in my 340, the cable has to be wound left handed. speedo cable is right handed, and will unwind.only place I seen so far is Pegasus, 1 800 688 6946. might try stewart warner, they are making that tach again. good luck. the dist has a round end with a blade , tach has .104 sq end.
[Re: perfmachst]
#1978718
12/29/15 05:39 PM
12/29/15 05:39 PM
Posts: 466 Keminmaa
ArcticCuda
Keminmaa
hi , I have same setup in my 340, the cable has to be wound left handed. speedo cable is right handed, and will unwind.only place I seen so far is Pegasus, 1 800 688 6946. might try stewart warner, they are making that tach again. good luck. the dist has a round end with a blade , tach has .104 sq end. Correct, dist is 7/8" and tach 5/8". My english is not good enough to make a phone call but I just sent email to Stewart Warner.
