Page 13 of 48 1 2 11 12 13 14 15 47 48
Re: Modern Bullitt build [Re: Keepat] #1978454
12/29/15 11:09 AM
12/29/15 11:09 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Un believable creativity here Bro! This is so clean . Having built engineering scale models of Oil refineries and nuclear power plants I truly appreciate your piping design and layout. Perfection!
Driving modern convenience in classic beauty
Re: Modern Bullitt build [Re: Darius] #1978599
12/29/15 03:06 PM
12/29/15 03:06 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you! sound like you have a cool job or is it a hobby building scale models?
Pat
Re: Modern Bullitt build [Re: Keepat] #1978600
12/29/15 03:07 PM
12/29/15 03:07 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Ok this is the last of the pluming work (for now ;-) Before I put all the tubing tools away I bent up the rear brake lines. As the rear has no brake line clips I made 2 weld on S/S straps to go on the U bolts and 2 S/S clips that I drilled and taped onto one of the 4 link mounts.
Pat
Re: Modern Bullitt build [Re: Keepat] #1978789
12/29/15 07:10 PM
12/29/15 07:10 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Pat
It was a job I had in the late '70's. I worked at Ralph Parsons Engineering in Pasadena and Bechtel in San Francisco. Unfortunately ,the commute was so bad I decided to go back to cabinet making which led to me starting my own shop and I have been in the residential remodeling business ever since.
BIG fun building those models to perfecting scale as part of the design process. The models were then used on site by the contractors for 3d reference. It was one of those jobs where they had to kick me out at closing time.
Re: Modern Bullitt build [Re: Darius] #1982003
01/02/16 03:29 PM
01/02/16 03:29 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I put the charger on the rotisserie so I can finish the bottom and prime it. I also have a small floor repair.
Pat
Re: Modern Bullitt build [Re: Keepat] #1983217
01/04/16 01:25 AM
01/04/16 01:25 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Had a few helpers stop by the shop today ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #1983503
01/04/16 04:17 PM
01/04/16 04:17 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Yeah! They are waiting for you to finish so they can join you in a window down, B-body cruise!
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Modern Bullitt build [Re: Keepat] #1983569
01/04/16 05:52 PM
01/04/16 05:52 PM
Vancouver,BC
Bullitt Guy Offline
Bullitt Guy  Offline
Vancouver,BC
I have been following this build since last summer and am amazed at your attention to detail and fabrication. This is an amazing project.
I have a Bullitt replica that I restored in 2006, stock appearing with addition of some suspension upgrades.
http://vancouverclassiccars.com/VancouverClassicCars/DODGE_CHARGER.html
The car has this appearance full time now.
http://s285.photobucket.com/user/paulolds/media/Dodge%20Charger/IMG_3016.jpg.html
You should plan to bring your completed car to MCACN in Chicago when finished.
Paul
Re: Modern Bullitt build [Re: tpabayflyer] #1983671
01/04/16 08:22 PM
01/04/16 08:22 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
They do like to cruise with the window down ;-)
Pat
Re: Modern Bullitt build [Re: Bullitt Guy] #1983675
01/04/16 08:27 PM
01/04/16 08:27 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Paul
Paul,
Awesome Bullitt Charger you have!!! I hope my Charger looks as nice as yours 1 day! Thank you for links as it is always great to see other black 68 Chargers.
Thanks again!
Pat
Re: Modern Bullitt build [Re: Keepat] #1986213
01/08/16 12:36 PM
01/08/16 12:36 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Started installing the torque boxes and have the left aft welded in. The US Car Tool boxes fit nice and only need a little adjustment. I added a 1 ½” hole for a future rear brake vent.
Pat
Re: Modern Bullitt build [Re: Keepat] #1986215
01/08/16 12:40 PM
01/08/16 12:40 PM
mopar4don Offline
mopar4don  Offline
Keep them pics coming!
I absolutely love it!
Your thread helps me a lot as I will be adding these to my Charger
Re: Modern Bullitt build [Re: mopar4don] #1986347
01/08/16 04:01 PM
01/08/16 04:01 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Don, You keep the pictures coming also, as I enjoy following your build!
Thank you!
Re: Modern Bullitt build [Re: Keepat] #1986384
01/08/16 04:41 PM
01/08/16 04:41 PM
mopar4don Offline
mopar4don  Offline
Thank you!
Pat, It's obvious you've done this before.
Guys like me (novice) are learning from guys like you.
So thank you!
I will keep my pics coming on my build (I am behind)
Re: Modern Bullitt build [Re: Keepat] #1987987
01/10/16 10:47 PM
01/10/16 10:47 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I started on the driveshaft loop/crossmember today. Using a press I oval a 2” section of 6” pipe and hammered the top half to match the shape of the driveshaft tunnel. With the loop clamped in place and using a 15” contour gauge (a must have tool) I made two cardboard pattern for the crossmember. With the cardboard center section of each pattern as wide as the square tubing (2”) I was able to lay it over the tubing to get a precise line to cut with the plasma cutter. I still need to make the pattern for inside the tunnel above the loop before I can weld it to the floor.
Pat
Re: Modern Bullitt build [Re: Keepat] #1989503
01/12/16 10:02 PM
01/12/16 10:02 PM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
AMAZING ABSOLUTELY AMAZING WORK !!! BEN FOLLOWING THIS RITE ALONG , MAKES ME WANT TO TAKE MY PROJECT TO THE NEXT LEVEL !!! LOVE IT !!!!!!
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: Modern Bullitt build [Re: sparcy] #1989622
01/13/16 12:24 AM
01/13/16 12:24 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
THANK YOU SIR ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #1990296
01/13/16 11:36 PM
01/13/16 11:36 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The drive shaft loop/crossmember is made and tack welded in place. Back to the torque boxes.
Pat
Re: Modern Bullitt build [Re: Keepat] #1992916
01/17/16 08:31 PM
01/17/16 08:31 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Finished up a few details on the front of the frame connectors today. Front torque boxes are next.
Pat
Re: Modern Bullitt build [Re: Keepat] #1994198
01/19/16 05:24 PM
01/19/16 05:24 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Good work Pat. I love the way over the top" engineering you are doing on this project. Patience is your virtue.
