Re: Question about heater core in 2008 Jeep Liberty.
[Re: moparx]
#1978956
12/29/15 11:07 PM
12/29/15 11:07 PM
Posts: 21,832 Kirkland, Washington
Pacnorthcuda
hot air, even if it's only one one side, indicates the core is ok. look at a blend door being broken or a blend door motor not working. very good possibility that was the original issue if you had heat in one position and not others. This is correct. Libertys are known for blend door issues. I believe specifically its that the door hinges on plastic pegs that just don't last but I am not positive on that. Google the kj jeep forum and they discuss it at length.
[Re: MN-ScatPack]
#1979510
12/30/15 06:31 PM
12/30/15 06:31 PM
Posts: 5,188 Twin Cities, MN
MN-ScatPack
Twin Cities, MN
Pretty sure its not the blend door. Like I said back in 2013 I had the same problem and the dealer claims they replaced the heater core which seemed to fix the problem until this year. Now the same problem. I took it in two weeks ago and they said they flushed the heater core which again appeared to of fixed the problem but this time only for a week or so. Now they claim the heater core needs to be replaced again for another $1400! My question is do you think an independent shop would be able to tell if the original core was ever replaced? I found a shop that will replace it for $650 but I want to know if the one he takes out is the original core or a replacement. If he says its original then the stealership is going to owe me $1400 from two years ago!
[Re: MN-ScatPack]
#1979558
12/30/15 07:57 PM
12/30/15 07:57 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
It will pretty difficult to tell you if the heater core was replaced after being in there for 2 years. I would find a shop and have the heater core flushed before spending all that money. I have done hundreds of heater core flushing with success, I use a garden hose and some air pressure, go back n forth through the tubes.(also add small piece of heater hoses into an empty bottle, so I can see what is coming out). always clear up, (just limit the air pressure so you don't blow the heater core apart). The heater core can be partially plugged, that is why you have heat on 1 side but not the other, just because you had this problem before,doesn't mean that it is the same problem. blend air doors and actuators do go bad. listen carefully, when you switch from cold to heat, you will hear an airflow change.if not the door isn't moving. FLUSH it first, before spending the money. Go to an independent shop and have it done.dealer is not the best place to go for a flush.
If you are plugging up heater cores this fast, you must have some nasty coolant, you have way more problems coming.
