A Body gas pedal,....too much "slop"....????? #197838
01/19/09 09:20 AM
01/19/09 09:20 AM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
While I've got my car 1/2 apart for my 4spd project, I've decided to look into a long standing issue with my gas pedal. The darn pedal just seems to have a ton of play in it. Not up and down play, like it's supposed to have, but side to side. The thing just seems too sloppy! My FSM doesn't show a good picture /diagram of the pedal attachment, so I can't tell if some small parts are missing (springs and stuff). Either way, it looks overly complicated from the factory.
Does anybody else have a sloppy pedal? Any pictures of the back of a pedal where the plastic pedal attaches to the steel?
Re: A Body gas pedal,....too much "slop"....????? [Re: LAR_414] #197839
01/19/09 09:40 AM
01/19/09 09:40 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Larry,
There is a spring to keep tension on the pedal. The pedal rod slides into 2 slots in the back of the pedal and the spring is sandwiched between the slots. One of the slots may be broken. Sorry, no pix.
Re: A Body gas pedal,....too much "slop"....????? [Re: Pntastar69] #197840
01/19/09 10:08 AM
01/19/09 10:08 AM
P
Pntastar69 Offline
Pntastar69  Offline
P
Re: A Body gas pedal,....too much "slop"....????? [Re: Pntastar69] #197841
01/19/09 10:17 AM
01/19/09 10:17 AM
LAR_414 Offline OP
LAR_414  Offline OP
THanks Mark.
That E-bay kit is great,....too bad my car is not a 67-68. My 69 Dart looks a little different than that kit shows. I don't even know what the black thing is in that kit.
Anybody else got some pictures? Even a kit for a 1969 A-body?
Which way is the tension supposed to be pushing the plastic pedal?
Re: A Body gas pedal,....too much "slop"....????? [Re: LAR_414] #197842
01/19/09 10:55 AM
01/19/09 10:55 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The spring on my car pushes the pedal down so the lower portion is being pushed toward the floor. The upper portion is being pushed away from the floor.
Re: A Body gas pedal,....too much "slop"....????? [Re: 69Cuda340S] #197843
01/19/09 01:05 PM
01/19/09 01:05 PM
LAR_414 Offline OP
LAR_414  Offline OP
Thanks for the info. I'm sure I'm going to have to get creative a little here, cuz I don't like the slop right now.
Re: A Body gas pedal,....too much "slop"....????? [Re: LAR_414] #197844
01/19/09 11:11 PM
01/19/09 11:11 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Larry, Give me a few days and I'll try to get you a pic of my pedal. Mike
Re: A Body gas pedal,....too much "slop"....????? [Re: LAR_414] #197845
01/19/09 11:39 PM
01/19/09 11:39 PM
here
Re: A Body gas pedal,....too much "slop"....????? #197846
01/20/09 09:01 AM
01/20/09 09:01 AM
LAR_414 Offline OP
LAR_414  Offline OP
Thanks guys....After cleaning the crud out, I found that one side has an allen head. So I tighten it up and the pedal is nice now. No more side to side slop. I didn't take it apart, so I don't know fully how it goes together, but I also don't care now. It's much much better now. It just looks like an overly complicated (lots of small parts)part to do a simple job.
Re: A Body gas pedal,....too much "slop"....????? [Re: LAR_414] #197847
01/20/09 12:57 PM
01/20/09 12:57 PM
P
Pntastar69 Offline
Pntastar69  Offline
P
Plumb forgot about that allen screw.
