Re: Which M1 Manifold Do I Buy?
[Re: patosmith]
#1978199
12/28/15 10:59 PM
12/28/15 10:59 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
My first choice is a 4150 intake. If you have the room a 2 inch 4500 (dominator) to 4150 adapter allows you to use the dominator on a 4150 intake if you choose to go that way or you can use the 4150 carb. The adapters work very well and many swear work better than a 4500 intake.
What I do is mill 1/4" off the top of the adapters and glue (using Seal-All) a 1/4 inch of phenolic. I glass bead the phenolic or sand it so the glue sticks. I then blend the phenolic into the adapater. The phenolic is a great heat insulator and that is why I use it.
[Re: AndyF]
#1978209
12/28/15 11:13 PM
12/28/15 11:13 PM
Posts: 295 Spanaway, Washington State
patosmith
On a 505 inch engine I'd use the 4500 flange intake since it has a much larger plenum. Then I'd buy a new carb with the dual flange base plate such as the Holley Ultra XP. An 850 DP would probably be the right carb for a 505 engine but it depends on how hard you spin it.
You might need a short plate between the carb and the intake to allow the throttle linkage to clear. I make a plate that does the trick but you can also use a simple spacer or grind some clearance into the intake. I am using the new trick flow 240 heads so maybe the 4500 with the larger plenum is the way to go. The heads look like they will breathe pretty good.
