Bucket seat weld in supports #197733
01/18/09 11:51 PM
01/18/09 11:51 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Getting ready to make up some bucket seat supports (going from bench to buckets) for my Demon. What thickness/guage of metal should I use?
Re: Bucket seat weld in supports [Re: VITC_GTX] #197734
01/19/09 12:13 AM
01/19/09 12:13 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I just put some 4" diameter washers under my bucket seat bolt holes. 4 years of abuse and it's still perfect.
Re: Bucket seat weld in supports [Re: VITC_GTX] #197735
01/19/09 12:54 AM
01/19/09 12:54 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
use approx. 1/8" steel, 3"x4" or larger. weld it in on the top of the pan and only the inner set of holes for both seats, the outers are supported by the same brace as the bench seat mounts
Re: Bucket seat weld in supports [Re: nomore65BelvJim] #197736
01/19/09 01:16 AM
01/19/09 01:16 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks.
Re: Bucket seat weld in supports [Re: nomore65BelvJim] #197737
01/19/09 02:32 AM
01/19/09 02:32 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I agree...... but.......
Why on top and not the bottom???
Also radius the corners to relieve and potential stress points. Pointed corner on stressed members is bad.
Re: Bucket seat weld in supports [Re: RobX4406] #197738
01/19/09 04:56 PM
01/19/09 04:56 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Because on top is where the factory put them and they also served to level the seats. If you just make something up you're going to have to play with washers to get the seats level. No big deal.
Re: Bucket seat weld in supports [Re: Stanton] #197739
01/19/09 07:03 PM
01/19/09 07:03 PM
Manitoba, Canada
Manitoba, Canada
Yeah that's what I had to do. 4" diameter washers underneath and a 4" diameter washer on top under the rug. Had to stack em up a couple times to get the seat level. No big deal, it's under the rug where nobody sees it.
