Re: door will not latch closed 68 Charger
[Re: frank]
#1976719
12/26/15 08:10 PM
12/26/15 08:10 PM
moparpollack
Lil Herman
Lil Herman
85086
Lazy star wheel that needs to be synced up to the door latch. Not all the star wheel arms are the same length, turn the star wheel until the door shuts.
[Re: frank]
#1976755
12/26/15 09:17 PM
12/26/15 09:17 PM
Posts: 4,920 new berlin wisconsin
Mr T2U
my guess is either the spring broke for the lever that catches the star wheel on the inside of the latch. or it somehow got stuck.
perception is 90% of reality
[Re: Mr T2U]
#1976759
12/26/15 09:24 PM
12/26/15 09:24 PM
Posts: 2,138 tucson az
frank
tucson az
my guess is either the spring broke for the lever that catches the star wheel on the inside of the latch. or it somehow got stuck. Where is this spring at? Behind the door panel? Any way to check without taking any thing apart?
[Re: Powerflow]
#1976943
12/27/15 02:57 AM
12/27/15 02:57 AM
Posts: 10,559 Freeport IL USA
poorboy
Freeport IL USA
Try hosing down the lock mechanism with brake cleaner to get the crud out, then re-lube everything and see how it works. This one! I'm betting the latch mechanism is gummed up. Clean it up & re-lube it and it ill probably work. Gene
[Re: ink]
#1977097
12/27/15 02:10 PM
12/27/15 02:10 PM
frank
tucson az
does it not latch at all??? or just not tight? on my 69 bee I had to adjust latch further apart to get second click on star .one click door will be ajar....2 clicks and doors shut tight. It does not latch tight. The door will close but it is loose. The latch mechanism is not gummed up. How do you adjust the latch further apart?
[Re: frank]
#1977104
12/27/15 02:15 PM
12/27/15 02:15 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
does it not latch at all??? or just not tight? on my 69 bee I had to adjust latch further apart to get second click on star .one click door will be ajar....2 clicks and doors shut tight. It does not latch tight. The door will close but it is loose. The latch mechanism is not gummed up. How do you adjust the latch further apart? You don't adjust the latch,you have to move the door strike on the pillar.Loosen the three Phillips screws,move it up or down,in or out,whatever it takes.Don't move it a lot at one time,doesn't take much and it could take a while until you get it right.
