Re: EGR Question
[Re: Omni Source 1]
#1975104
12/23/15 01:27 PM
12/23/15 01:27 PM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
Years ago on the vacuum ones they had 1 number aftermarket.Then you had different orrifices you put in for different EGR oe numbers.I agree just get one from Rock.We used mostly all aftermatkets at the shop back then.Rocky
Chrysler Firepower
Re: EGR Question
[Re: DaytonaTurbo]
#1975166
12/23/15 03:17 PM
12/23/15 03:17 PM
RapidRobert
Can you not just bypass it? that's what I was thinking too, if it dont ping from the now undiluted with ex gas mixture then you're fine unless it needs to be hooked up for emissions inspection in your area. You'll gain power and mileage
Re: EGR Question
[Re: Omni Source 1]
#1975210
12/23/15 04:36 PM
12/23/15 04:36 PM
therocks
Niles , Ohio
Some you could plug in the day.Others would ping like crazy.IIRC aftermarket EGR isnt that pricey.Some of the early ones like GMs for sure you could take apart and clean if carboned up.Rocky
Chrysler Firepower
Re: EGR Question
[Re: therocks]
#1975426
12/23/15 10:48 PM
12/23/15 10:48 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
First is if you have to have the car emission tested they check the Nox which most likely will fail without the EGR working. Second is many will ping with the EGR unhooked as some call the EGR the poor mans octane booster because it lowers combustion chamber temps when working since the inert gas wont ignite and I can tell you some cars would ping bad with the EGR not working. I cant remember if that year has the transducer on it that has exh flow back pressure on it to control when the valve opens as if it does many times the aftermarket valve dont work to good. It can come in to soon and cause a stumble on light throttle or come in way to late. Hopefully a Mopar parts person will chime in and give you the right part number valve thats calibrated correct. Ron
Re: EGR Question
[Re: Omni Source 1]
#1975452
12/23/15 11:34 PM
12/23/15 11:34 PM
therocks
Niles , Ohio
Ron not many countys in Ohio have emmission tests.That and IIRC older car are usually exempt.Rocky
Chrysler Firepower
Re: EGR Question
[Re: therocks]
#1976428
12/26/15 02:01 AM
12/26/15 02:01 AM
383man
Balt. Md
Ron not many countys in Ohio have emmission tests.That and IIRC older car are usually exempt.Rocky Thanks as I did not know that. In Md about the only ones that dont get it are Historic or HotRod tagged cars. Ron
