SB Cam recomendations #1971707
12/17/15 10:15 PM
12/17/15 10:15 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Gonna be
11 to 1 comrpession
Ported magnum heads 2.02 valves should flow 250 easy
M1 single plane
1 3/4 headers dual 3 inch ex with X pipe and magnaflows
410 inches
Big gulp throttle body
44RE trans factory high stall converter
4.56 gears for now probably go back to the 3.92s
.035 quench
Needs to work with the factory EFI in my 99 dakota R/T, I do have an SCT tuner
Don't need power brakes but got to have enough vaccum for the climate control stuff
Don't want to ever turn past 6000 RPM even 5500 is better
Daily driver 9 months of the year
Prefer not to have a rough/bucking idle but a little noticable is OK.
I am thinking hydraulic roller would make me happiest.
Needs to run on 93 octane with no bandaids like water injection.
I will be running a return to keep the fuel cooler and a good cold air intake set up.
Just wondering what all the gurus say.
Re: SB Cam recomendations [Re: HotRodDave] #1971712
12/17/15 10:22 PM
12/17/15 10:22 PM
Kalispell Mt.
Kalispell Mt.
May someday step up to a ported eddy magnum.
Re: SB Cam recomendations [Re: HotRodDave] #1971734
12/17/15 10:52 PM
12/17/15 10:52 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have no experience w/ combinations like that, but did see that Hughes Engines provides a variety of build guidelines for each of its SB hydraulic rollers listed on their web site that might help w/ your decision.
Re: SB Cam recomendations [Re: HotRodDave] #1971743
12/17/15 11:05 PM
12/17/15 11:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Lock up converter?
Cruise rpm in OD?
Rockers?
Ratio?
Re: SB Cam recomendations [Re: HotRodDave] #1971759
12/17/15 11:27 PM
12/17/15 11:27 PM
Kalispell Mt.
Kalispell Mt.
I have 1.6 and 1.7 mopar roller rockers
Yes LU.
Cruise most of the time just a little over 2000 and want power instantly when I tip into it. I love good throttle response and TQ. Out on the highway it's a little over 2500.
Re: SB Cam recomendations [Re: HotRodDave] #1971762
12/17/15 11:29 PM
12/17/15 11:29 PM
Kalispell Mt.
Kalispell Mt.
I would prefer to use the 1.7 rockers, they are brand new.
Re: SB Cam recomendations [Re: HotRodDave] #1971802
12/18/15 12:12 AM
12/18/15 12:12 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
What lift will your valve springs support?
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: SB Cam recomendations [Re: HotRodDave] #1971809
12/18/15 12:16 AM
12/18/15 12:16 AM
Kalispell Mt.
Kalispell Mt.
The ones I have now I ran at .575 but don't remember what they were capable of. That is probably a good lift to stay under as the flow probably don't go up after that. Also hard to get much more lift in the magnum head without longer valves.
Re: SB Cam recomendations [Re: HotRodDave] #1971862
12/18/15 01:10 AM
12/18/15 01:10 AM
So. Burlington, Vt.
So. Burlington, Vt.
So, it looks like the choices get narrowed down pretty quickly in this type of combo.
Since you'll be using 1.7 rockers and want to use it as a semi daily driver I would keep the ramps pretty soft. I'd be looking at low 220's @ .050, maybe 4-6deg split(maybe more depending on the whole exhaust system), 110-112 lsa.
With the short duration and slower ramps you'd easily be less than .575 lift.
Re: SB Cam recomendations [Re: HotRodDave] #1972125
12/18/15 02:32 PM
12/18/15 02:32 PM
Kalispell Mt.
Kalispell Mt.
Thanks... I just gave a friend almost that exact cam, 221@.050 110 LSA single pattern that cam in a hair under .575 with the 1.7s.
The whole exhaust system is awesome, 3 inch mandrel bent, full length ceramic coated headers, all aluminized... the guy I got it from owns an exhaust shop and hand built it for his own 99 R/T dakota. I traded for it when he put his back to stock.
Re: SB Cam recomendations [Re: HotRodDave] #1974569
12/22/15 03:13 PM
12/22/15 03:13 PM
Kalispell Mt.
Kalispell Mt.
Would that cam make enough vacuum for the MAP sensor and accessories?
Re: SB Cam recomendations [Re: HotRodDave] #1974582
12/22/15 03:33 PM
12/22/15 03:33 PM
So. Burlington, Vt.
So. Burlington, Vt.
It would certainly work with aftermarket efi, but I don't know how much adjustment is "built in" to the OE unit.
My guess is, it's probably pushing the limits. If you were looking for something "safer", knock 5-6deg out of it and maybe spread it out a degree or two.
