SB Cam recomendations
#1971707
12/17/15 10:15 PM
12/17/15 10:15 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Gonna be
11 to 1 comrpession Ported magnum heads 2.02 valves should flow 250 easy M1 single plane 1 3/4 headers dual 3 inch ex with X pipe and magnaflows 410 inches Big gulp throttle body 44RE trans factory high stall converter 4.56 gears for now probably go back to the 3.92s .035 quench Needs to work with the factory EFI in my 99 dakota R/T, I do have an SCT tuner Don't need power brakes but got to have enough vaccum for the climate control stuff Don't want to ever turn past 6000 RPM even 5500 is better Daily driver 9 months of the year Prefer not to have a rough/bucking idle but a little noticable is OK. I am thinking hydraulic roller would make me happiest. Needs to run on 93 octane with no bandaids like water injection. I will be running a return to keep the fuel cooler and a good cold air intake set up.
Just wondering what all the gurus say.
Re: SB Cam recomendations
[Re: HotRodDave]
#1971712
12/17/15 10:22 PM
12/17/15 10:22 PM
HotRodDave
Kalispell Mt.
May someday step up to a ported eddy magnum.
[Re: HotRodDave]
#1971759
12/17/15 11:27 PM
12/17/15 11:27 PM
HotRodDave
Kalispell Mt.
I have 1.6 and 1.7 mopar roller rockers Yes LU. Cruise most of the time just a little over 2000 and want power instantly when I tip into it. I love good throttle response and TQ. Out on the highway it's a little over 2500.
[Re: HotRodDave]
#1971762
12/17/15 11:29 PM
12/17/15 11:29 PM
HotRodDave
Kalispell Mt.
I would prefer to use the 1.7 rockers, they are brand new.
[Re: HotRodDave]
#1971802
12/18/15 12:12 AM
12/18/15 12:12 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
What lift will your valve springs support?
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: HotRodDave]
#1971809
12/18/15 12:16 AM
12/18/15 12:16 AM
HotRodDave
Kalispell Mt.
The ones I have now I ran at .575 but don't remember what they were capable of. That is probably a good lift to stay under as the flow probably don't go up after that. Also hard to get much more lift in the magnum head without longer valves.
[Re: HotRodDave]
#1971862
12/18/15 01:10 AM
12/18/15 01:10 AM
fast68plymouth
So. Burlington, Vt.
So, it looks like the choices get narrowed down pretty quickly in this type of combo. Since you'll be using 1.7 rockers and want to use it as a semi daily driver I would keep the ramps pretty soft. I'd be looking at low 220's @ .050, maybe 4-6deg split(maybe more depending on the whole exhaust system), 110-112 lsa. With the short duration and slower ramps you'd easily be less than .575 lift.
[Re: HotRodDave]
#1972125
12/18/15 02:32 PM
12/18/15 02:32 PM
HotRodDave
Kalispell Mt.
Thanks... I just gave a friend almost that exact cam, 221@.050 110 LSA single pattern that cam in a hair under .575 with the 1.7s.
The whole exhaust system is awesome, 3 inch mandrel bent, full length ceramic coated headers, all aluminized... the guy I got it from owns an exhaust shop and hand built it for his own 99 R/T dakota. I traded for it when he put his back to stock.
[Re: HotRodDave]
#1974569
12/22/15 03:13 PM
12/22/15 03:13 PM
HotRodDave
Kalispell Mt.
Would that cam make enough vacuum for the MAP sensor and accessories?
[Re: HotRodDave]
#1974582
12/22/15 03:33 PM
12/22/15 03:33 PM
fast68plymouth
So. Burlington, Vt.
It would certainly work with aftermarket efi, but I don't know how much adjustment is "built in" to the OE unit. My guess is, it's probably pushing the limits. If you were looking for something "safer", knock 5-6deg out of it and maybe spread it out a degree or two.
