should this make 600 hp
#1973499
12/20/15 10:29 PM
12/20/15 10:29 PM
Posts: 1,285 okla.
sam64
okla.
470 low deck 11.3 comp,.586 solid lifter 286 dur,259@.050,pro maxx 78 cc heads,hs 1.5 rockers,383 victor or m-1 intake,2"headman headers.if not what changes need made.thanks,Sam,
Re: should this make 600 hp
[Re: sam64]
#1973555
12/21/15 12:42 AM
12/21/15 12:42 AM
Posts: 43,263 Bend,OR USA
Cab_Burge
Which heads and port sizes?
[Re: Cab_Burge]
#1973596
12/21/15 01:44 AM
12/21/15 01:44 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Which heads and port sizes? Yes and what do the heads flow ? Ron
[Re: sam64]
#1973961
12/21/15 06:10 PM
12/21/15 06:10 PM
Posts: 570 UK
rb446
UK
I doubt it either, my mate ran a 12.7:1 domed JE piston 440, MC Eddy heads 320cfm, DC.590 solid, Victor intake and 1050 Dommy w/2" hdrs, track hp worked out to 588 on his best 10.1@131mph/3150 weight, this wasn't a "fresh" motor though, might've picked up a bit with a re-ring. I personally thought it was a bit under cammed and could've gone in the 9's with my old CC.650", 290@.050 solid I used to run.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: sam64]
#1974112
12/21/15 10:45 PM
12/21/15 10:45 PM
BradH
... pro maxx 78 cc heads... Out of the box, or w/ a basic bowl blend? No. With some fairly extensive port work? Probably, with the right tuning of the rest of the combination. You don't mention the intended carb, either, which could be another limitation.
[Re: sam64]
#1974190
12/22/15 12:15 AM
12/22/15 12:15 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some of you guys calculate your flow to horsepower improperly . Let's assume your heads flow 310 cfm at .700 lift or .750 but you are only running a 590 lift cam. Now let's subtract lash and deflection and we are now down to .555 lift or possibly less. Now what are your flow numbers for the split second that you are at .555 max lift. I'll tell you this, you are nowhere near 310 cfm
[Re: pittsburghracer]
#1974323
12/22/15 03:35 AM
12/22/15 03:35 AM
Posts: 7,506 Az
Crizila
Az
Some of you guys calculate your flow to horsepower improperly . Let's assume your heads flow 310 cfm at .700 lift or .750 but you are only running a 590 lift cam. Now let's subtract lash and deflection and we are now down to .555 lift or possibly less. Now what are your flow numbers for the split second that you are at .555 max lift. I'll tell you this, you are nowhere near 310 cfm rat on!
Fastest 300
[Re: onebadfish]
#1974327
12/22/15 03:56 AM
12/22/15 03:56 AM
Posts: 610 long time lurker, short time p...
PorkyPig
I have a 512 with promax heads - 11.2/1 compression. I dynoed last week at 608 hp and 649 torque. Heads are cnc flowing 335. Cam is 260 @ .050. Roller rockers with 1.5 to 1 ratio. Cam is a solid flat tappet and intake is a 6 pack port matched to the heads and ported. I think you may be a little short with a 470 cubic inch motor. I think you are down 40 or more HP from where what you described should make. What are you running for headers? Or maybe even "ported" a 6bbl intake is holding it back.
#1974558
12/22/15 02:48 PM
12/22/15 02:48 PM
Posts: 570 UK
rb446
UK
Some of you guys calculate your flow to horsepower improperly . Let's assume your heads flow 310 cfm at .700 lift or .750 but you are only running a 590 lift cam. Now let's subtract lash and deflection and we are now down to .555 lift or possibly less. Now what are your flow numbers for the split second that you are at .555 max lift. I'll tell you this, you are nowhere near 310 cfm x2.....spot on!
[Re: sam64]
#1974565
12/22/15 03:03 PM
12/22/15 03:03 PM
Thumperdart
State of confusion
the bowls on these heads look really good compared to eddys,the casting looks smoother and bowl looks better designed.I did gasket match the intake ports.carb is a quick fuel 850 race carb. I think you could use more carb...............
[Re: onebadfish]
#1974718
12/22/15 07:35 PM
12/22/15 07:35 PM
Posts: 126 Oregon
Jamie McGrath
I have a 512 with promax heads - 11.2/1 compression. I dynoed last week at 608 hp and 649 torque. Heads are cnc flowing 335. Cam is 260 @ .050. Roller rockers with 1.5 to 1 ratio. Cam is a solid flat tappet and intake is a 6 pack port matched to the heads and ported. I think you may be a little short with a 470 cubic inch motor. It couldn't be that simple, a few questions if you will.....What was the cams lift? What did the 6 pack intake flow as there notorious for core shift. What did you do too the carbs? Swap in a 4412 for the center carb?
