hemi or wedge #1973340
12/20/15 05:23 PM
12/20/15 05:23 PM
ohio
slomoshun Offline OP
ohio
just for fun if you were going to build a new engine for a pulling truck which would you build hemi or wedge? what bore and stroke? what heads? here are the rules
1. no power adder
2. single 4150 carb
3. 472 cubes
4. no alum head
5. no alum block
6. no dry sump
Re: hemi or wedge [Re: slomoshun] #1973351
12/20/15 05:41 PM
12/20/15 05:41 PM
IN
ahy Offline
ahy  Offline
IN
Just for fun an answer... given no aluminum heads, I'd go Hemi. The OE iron heads can make a lot of power. It would have to be geared to allow the engine to run pretty fast... up to 7000 RPM or even more on a max effort deal. An iron Siamese block would get you the cubes with a standard 3.75 stroke crank with around 4.45" bore.
Re: hemi or wedge [Re: slomoshun] #1973352
12/20/15 05:42 PM
12/20/15 05:42 PM
AndyF Offline
AndyF  Offline
Hemi cast iron heads are going to make a lot more power than any stock BB cast iron heads. If you look around a bit you might find a set of Indy -1 cast iron heads. If you can find the iron -1 heads then it would be cheaper to build a wedge and it would probably make just as much power.
Another option is to find some older cast heads from a NHRA super stock guy. Heads that are no longer competitive in SS might work just fine for a puller engine. Might need a sheet metal intake though to work with the heads since they move the ports around in those things.
Big bore and short stroke will make the most power. Then you'll have to sort out the gear ratios to make it pull hard.
Good luck either way.
Re: hemi or wedge [Re: AndyF] #1973354
12/20/15 05:44 PM
12/20/15 05:44 PM
west palm beach, florida
modelmakerinc Offline
Set of iron 440-1 heads in race parts for sale right now and priced very well.
JUST SAYIN.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: hemi or wedge [Re: slomoshun] #1973421
12/20/15 07:58 PM
12/20/15 07:58 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
Mike of mrl performance built an engine for a pulling truck with the same ruler, that build was featured in hotrod
http://www.hotrod.com/how-to/engine/1307-dodge-pulling-truck-chrysler-400-engine-build/
Re: hemi or wedge [Re: slomoshun] #1973433
12/20/15 08:17 PM
12/20/15 08:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Iron indy heads
Re: hemi or wedge [Re: slomoshun] #1973446
12/20/15 08:33 PM
12/20/15 08:33 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Don't they make a 1000 cfm 4150 now? I would do a Hemi, but that is because I am partial to Hemi's. Initial cost might be more but I think that there is more torque potential with a single carb tunnel run. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: hemi or wedge [Re: slomoshun] #1974317
12/22/15 03:22 AM
12/22/15 03:22 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Hemi with a Barton intake on it.
Re: hemi or wedge [Re: slomoshun] #1974362
12/22/15 08:43 AM
12/22/15 08:43 AM
SW WI
cudacustoms1 Offline
SW WI
I have seen several guy's try the -1's in the 4wd trucks and the same thing happens. They run ok but never get to the front.I have ran 572-13's with the same problem. If i was going to try it and they didn't have a rule outlawing hemis (just about every lower level pulling club dose). Thats the way i would go. The build cost might be alittle more at first but you will also have something that is worth a lot more in the end. There are more tech/parts for the hemi also.If you do build it keep an eye on your bearings/oil pressure. Both tend to suck the pan dry on long runs. Trut me! I learned the hard way. Good luck
