Re: can someone help identify my holley carb? [Re: AHall] #197296
01/18/09 10:40 PM
01/18/09 10:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Most likely another Holley though to be honest the one you already have isn't a bad choice, just rebuild it or have it rebuilt...The 3310 is a very good general performance vacuum secondary carb...
Re: can someone help identify my holley carb? [Re: 1_WILD_RT] #197297
01/18/09 10:50 PM
01/18/09 10:50 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Think you will find it's not the base gasket leaking, but the throttle shaft. The list # will tell what you have, my guess is a 3310 = 750 vacuum secondary
rruner nails it...
"Thank You, Thank You, Thank You Very Much"
Re: can someone help identify my holley carb? [Re: rrunner] #197298
01/19/09 09:00 AM
01/19/09 09:00 AM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
thanks guys, I think im just going to replace the Holley with a PRO Series 4150 from Patrick at ProSystems.
Re: can someone help identify my holley carb? [Re: AHall] #197299
01/19/09 12:18 PM
01/19/09 12:18 PM
you might pull the carb & see if you can ID where it's leaking from & replace that gasket. from the pic it might be the AP gasket. I have an extra one you can have. Be alot cheaper than purchasing a whole new carb & it'll give you the satisfaction of solving the problem
Re: can someone help identify my holley carb? [Re: RapidRobert] #197300
01/19/09 05:11 PM
01/19/09 05:11 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
you are the man! Can I get your contact info?
Re: can someone help identify my holley carb? [Re: AHall] #197301
01/19/09 05:14 PM
01/19/09 05:14 PM
PM sent
Re: can someone help identify my holley carb? [Re: RapidRobert] #197302
01/19/09 10:31 PM
01/19/09 10:31 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I would just install a rebuild kit on the carb you have before spending the $ on a new one. I had a Speed Demon 750 vac seccondary in my 66 300 and it worked real nice. I'm sold on 4 corner idle adjust carbs since then. They idle smooooth.
Re: can someone help identify my holley carb? [Re: Lefty] #197303
01/19/09 11:14 PM
01/19/09 11:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: can someone help identify my holley carb? [Re: 1_WILD_RT] #197304
02/01/09 04:36 PM
02/01/09 04:36 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
I am going to attempt to rebuild it this weekend.
Can this carb be modded at all? It's a 3310 Holley FYI. I didnt know if the rebuild kit was standard or if there were any performance variation rebuild kits.
Re: can someone help identify my holley carb? [Re: AHall] #197305
02/01/09 04:53 PM
02/01/09 04:53 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
Ok see the first fuel feed, where it says HOLLEY, then there is that bulge bulging forward right beside it. Up under there under that lip is where it's now leaking like a sive. Any suggestions as to what that could be? That is where the leak is coming from though for sure.
Re: can someone help identify my holley carb? [Re: AHall] #197306
02/01/09 06:16 PM
02/01/09 06:16 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
the only way it could leak from where you said is a crack in the bowl. check to make sure it's not the fuel inlet or a bowl screw leaking and dripping down to that area, or maybe from the accelerator pump housing on the bottom of the bowl. there isn't really anywhere for it to leak from at the front of the bowl there. you should familiarize your self with your holley, they are very user friendly.
Re: can someone help identify my holley carb? [Re: dirtybee] #197307
02/01/09 07:20 PM
02/01/09 07:20 PM
St. John's Newfoundland
440newport Online content
440newport  Online Content
It could be leaking from one the bottom screws that hold the bowl on. They are sealed with a felt type washer and leak sometimes. It could be leaking from the acclerator pump area as well maybe.
