Spray Undercoating Touch-Up - What to Use? #1972415
12/18/15 11:56 PM
12/18/15 11:56 PM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
I need to touch-up some of the undercoating on the underside of my Cuda. I need something in a spray can that is similar to the factory black color and texture.
Does anyone have any recommendations on what I could use to duplicate the factory look? What have you used for your cars?
Thanks!
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1972425
12/19/15 12:12 AM
12/19/15 12:12 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
http://www.restorick.com/products.asp?cat=11
I think Resto-Rick has what your looking for but a quart is the smallest amount sold...
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1972441
12/19/15 12:38 AM
12/19/15 12:38 AM
Indianapolis, IN
Indianapolis, IN
I was hoping to be able to find something in a spray can so I wouldn't have to use my paint gun. The area I need to touch-up is so small...
Do you need a special type of gun to apply Resto-Rick's product, or can you use a regular HVLP gun?
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1972451
12/19/15 12:58 AM
12/19/15 12:58 AM
MD
floyd Offline
floyd  Offline
MD
I used this for some touch up with good results. It's tough and goes on well. It probably won't stand out too much if its just a small area.
http://www.amazon.com/TRANSTAR-4363-F-Quick-Rubberized-Undercoating/dp/B0015POVMW
There are a couple of different types listed at the bottom - "Customers Who Viewed This Item Also Viewed"
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1972490
12/19/15 01:48 AM
12/19/15 01:48 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I used a rubberized undercoating.....and pulsed the trigger, so it came out more with a textured look. from a foot away it is hard to tell its not factory.
My Monster are real!
Living within your means makes life pretty easy.
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1972608
12/19/15 12:42 PM
12/19/15 12:42 PM
Indianapolis, IN
Indianapolis, IN
Thanks guys. I'll probably buy the Transtar and also the 3M professional and test them both on some scrap metal before applying to my car. Pulsing the trigger is also a good idea. If I can apply it a little drier by having a light mist, with several coats, maybe I can duplicate the factory look.
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1972635
12/19/15 01:33 PM
12/19/15 01:33 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I use the 3M product for time to time.
A few years back there was a 3 M undercoat I used to get with a Green label and that was the best thick match.
Ron
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1972863
12/19/15 08:14 PM
12/19/15 08:14 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Don't forget to mask the car off.Any overspray from that undercoat is tuff to get off. twocents
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1972919
12/19/15 09:39 PM
12/19/15 09:39 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Some of the new {aerosol}formulas don't like being sprayed on too thick..You might get it built up to match the surrounding areas only to find it cracked while drying or shrank and needs another coat anyhow...Take your time and don't rush it if you go that route...
The old style undercoating had it's own spray gun that screwed on top of the container and splattered up everything including the floor..The discharge hole in that gun was almost as big as the air hose diameter itself...So you won't be running any thick undercoating through an HVLP paint gun no matter who's formula it is...
As stated cover everything including the floor it's going everywhere even if you use an aerosol can type product... I wear a disposable suit and old shoes.. there's no gracefull way to do it !!
thumbs
Re: Spray Undercoating Touch-Up - What to Use? [Re: screamindriver] #1973174
12/20/15 11:47 AM
12/20/15 11:47 AM
moparx Offline
moparx  Offline
thumbs
i believe it was called a "shutz" gun. hth
beer
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1973223
12/20/15 01:40 PM
12/20/15 01:40 PM
Indianapolis, IN
Indianapolis, IN
I figured it was going to be a messy proposition. Thanks for the info and suggestions.
If you can't use a normal paint gun, how is everyone applying Resto Rick's formula? Does it need a "shutz" gun?
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1973296
12/20/15 03:43 PM
12/20/15 03:43 PM
Harrisburg, Pa.
Harrisburg, Pa.
Yes, click on the above link QuickBpBp has posted {to Rick's site} and then click "details" for his undercoating...It makes reference to needing one of those guns...
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1973341
12/20/15 05:23 PM
12/20/15 05:23 PM
Indianapolis, IN
Indianapolis, IN
Got it. Thanks.
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1973451
12/20/15 08:41 PM
12/20/15 08:41 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
This is what the gun looks like.There are used ones out there.
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1973716
12/21/15 10:54 AM
12/21/15 10:54 AM
Indianapolis, IN
Indianapolis, IN
Thanks 5carguy. I was going to start looking for a gun, actually. How did you find yours?
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1973751
12/21/15 12:14 PM
12/21/15 12:14 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Saw this one on amazon, not sure if this is the same
http://www.amazon.com/gp/product/B003D3N...NQFSK3Z81M7KNRV
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1974409
12/22/15 11:07 AM
12/22/15 11:07 AM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
B5,The gun above is what you need.At under $15.00 you can't beat it.
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1974442
12/22/15 11:57 AM
12/22/15 11:57 AM
Indianapolis, IN
Indianapolis, IN
Perfect...thanks guys. I'm going to order one after the holidays.
Great info everybody!
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1976458
12/26/15 03:30 AM
12/26/15 03:30 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I used the Shutz coating years ago & it still did not go on like the factory undercoating. The OE stuff was SUPER thick & very rough textured. Still not sure how I'm going to re-apply the heavy build stuff to the quarters inside the trunk of my AAR. I'll have to talk with Frank Badalson to get some advice from him before I try.
Re: Spray Undercoating Touch-Up - What to Use? [Re: Sunroofcuda] #1976819
12/26/15 11:22 PM
12/26/15 11:22 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
For small touch up areas only u can use 3m seam sealer in a quart can. Get a 1" wide acid brush and dip in in the seam sealer agressively and then dab it on the spot. Practice and you find it duplicates it extremely well. It will however be a different color so u will have to shade it to whatever color u want. Works great in wheelhouse areas.
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1977621
12/28/15 01:12 AM
12/28/15 01:12 AM
Indianapolis, IN
Indianapolis, IN
Thanks mymcodebee. I'll give that a try as well. I've purchased a few different types of undercoating and I'm planning to practice on a piece of metal to see which ones have the best color and look.
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1979869
12/31/15 01:39 AM
12/31/15 01:39 AM
Shippensburg, PA
GardnersGotCudas Offline
Shippensburg, PA
3 m seam sealer spay gun
Re: Spray Undercoating Touch-Up - What to Use? [Re: B5Cuda440-6] #1983551
01/04/16 05:18 PM
01/04/16 05:18 PM
Sharpsburg Maryland
440farmer Offline
440farmer  Offline
Sharpsburg Maryland
does any of the mentioned undercoating dry enough to be painted over?
I've got the same problem on my wife's 71 challenger trunk
does any of this stuff NOT bleed through the paint??
