Who's push rods? #1971630
12/17/15 08:17 PM
12/17/15 08:17 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Today I called Trend, Manton and Smith Bros. Trends push rods come in .025" increments, not really what I'm looking for. I'd like to stay away from 3/8" as my Indy 360-1 are going to require some massaging to clear them. Not really a problem on the exhaust but the intake side may get thin.
Smith bros. recommend a .116" wall 5/16". Manton recommended a series 5 .120" wall 11/32". The Mantons are about $45 more than the Smith Bros and I don't mind paying the extra if it's worth it or needed.
PAC 1396 springs, 260# on the seat, 658# @ .740" lift.
Thanks.
Re: Who's push rods? [Re: justinp61] #1971641
12/17/15 08:34 PM
12/17/15 08:34 PM
Washington
madscientist Offline
Washington
There is no way I would use anything smaller than 3/8 with that. No way. And they SHOULD be 3/8-7/16 double taper. Didn't anyone say that?
I don't care for the 5/16 .120 walls I have with 145 on the seat.
EDIT
On second thought, you MAY get by with a 5/16-3/8 single taper. But that would be a .120 wall min.
Re: Who's push rods? [Re: madscientist] #1971660
12/17/15 08:56 PM
12/17/15 08:56 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have the 360-1 as well. It would take a ton of massaging to fit a 3/8 pushrod in there. I massaged for more pushrod clearance several times and a 5/16 is all that will fit. I used .116 last build but broke one from rubbing. .120 mantons are on my list.
Re: Who's push rods? [Re: justinp61] #1971664
12/17/15 09:01 PM
12/17/15 09:01 PM
Renton Washington
Triple Threat Offline
Renton Washington
7.8" 5/16 .120 wall Smith Brothers on my old engine.
250# on the seat
600# open @.640 lift
7000 RPM, T&D rockers. 600 runs in 3 seasons with no issues.
Bigger is better and stiffer, but if you can't fit it, I wouldn't be scared of the smaller pushrod.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Who's push rods? [Re: justinp61] #1971691
12/17/15 09:42 PM
12/17/15 09:42 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have some Manton 4 Series 11/32 x .120 wall 7.605/7.640 length push rods that I had on another motor with 360-2 heads that have about 15 passes on them. The engine broke a rod. If they will work I will sell them cheap.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Who's push rods? [Re: D-50] #1971696
12/17/15 09:59 PM
12/17/15 09:59 PM
oregon
greendart408 Offline
oregon
I run 3/8s x.120 smith bro's, in my uncles engine that's in my car, only brand we have ever ran, no issues. 360-1s, had to grind.... I might have got a 7/16s in there, which we wanted, was way thin already tho. 1.8 jesels, .800 plus lift cam, 330 and 810 pressures, if I remember correctly without looking at pressures.
Re: Who's push rods? [Re: D-50] #1971699
12/17/15 10:08 PM
12/17/15 10:08 PM
W. Kentucky
W. Kentucky
Ball, Ball? The exhaust are a right but the intakes are a little long. I've only measured one side will try to get the other side measured tomorrow.
Re: Who's push rods? [Re: justinp61] #1971704
12/17/15 10:13 PM
12/17/15 10:13 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Yes, Ball-Ball..
Re: Who's push rods? [Re: D-50] #1971890
12/18/15 01:39 AM
12/18/15 01:39 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use Manton pushrods in my 440/493 and they have worked great and their service was great. Ron
Re: Who's push rods? [Re: justinp61] #1971940
12/18/15 02:50 AM
12/18/15 02:50 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Trend made mine , any length that i needed.
Re: Who's push rods? [Re: CSK] #1971952
12/18/15 03:10 AM
12/18/15 03:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have used Trend, Smith Bro, and a local copany
to me.. they make what I want in straight PRs..
its called OEM.. I never had any bend or break..
but Smith Bro were way pricer than Trend and way
more than OEM... OEM makes Comp Cams PRs
EDIT
its a small place but the guy took me in back to
show me around and I was watching the one machine
putting the Comp Cams name and length on them going
into boxes.. pretty simple process on PRs but they
do nice stuff
wave
Re: Who's push rods? [Re: justinp61] #1971958
12/18/15 03:16 AM
12/18/15 03:16 AM
New York
polyspheric Offline
polyspheric  Offline
New York
"Not enough pushrod" doesn't always produce results that are easy to see and diagnose.
A limber pushrod acts like pole doing a pole-vault - it bends when the load vs. speed is too great, then snaps back to full length and overloads the spring. SpinTron is excellent in diagnosing this, but it's cheaper to just use the biggest diameter you can fit.
Sometimes, it isn't float or breakage - it's a soft spot in the RPM range you use that goes away when the pushrod is stiffer (not stronger).
Boffin Emeritus
