Re: Who's push rods?
[Re: justinp61]
#1971641
12/17/15 08:34 PM
12/17/15 08:34 PM
Posts: 4,457 Washington
madscientist
Washington
There is no way I would use anything smaller than 3/8 with that. No way. And they SHOULD be 3/8-7/16 double taper. Didn't anyone say that?
I don't care for the 5/16 .120 walls I have with 145 on the seat.
EDIT On second thought, you MAY get by with a 5/16-3/8 single taper. But that would be a .120 wall min.
[Re: justinp61]
#1971664
12/17/15 09:01 PM
12/17/15 09:01 PM
Triple Threat
Renton Washington
7.8" 5/16 .120 wall Smith Brothers on my old engine.
250# on the seat 600# open @.640 lift
7000 RPM, T&D rockers. 600 runs in 3 seasons with no issues.
Bigger is better and stiffer, but if you can't fit it, I wouldn't be scared of the smaller pushrod.
[Re: justinp61]
#1971691
12/17/15 09:42 PM
12/17/15 09:42 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have some Manton 4 Series 11/32 x .120 wall 7.605/7.640 length push rods that I had on another motor with 360-2 heads that have about 15 passes on them. The engine broke a rod. If they will work I will sell them cheap.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1971696
12/17/15 09:59 PM
12/17/15 09:59 PM
Posts: 1,075 oregon
greendart408
oregon
I run 3/8s x.120 smith bro's, in my uncles engine that's in my car, only brand we have ever ran, no issues. 360-1s, had to grind.... I might have got a 7/16s in there, which we wanted, was way thin already tho. 1.8 jesels, .800 plus lift cam, 330 and 810 pressures, if I remember correctly without looking at pressures.
[Re: D-50]
#1971699
12/17/15 10:08 PM
12/17/15 10:08 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I have some Manton 4 Series 11/32 x .120 wall 7.605/7.640 length push rods that I had on another motor with 360-2 heads that have about 15 passes on them. The engine broke a rod. If they will work I will sell them cheap. Ball, Ball? The exhaust are a right but the intakes are a little long. I've only measured one side will try to get the other side measured tomorrow.
[Re: justinp61]
#1971704
12/17/15 10:13 PM
12/17/15 10:13 PM
D-50
North, Alabama
I have some Manton 4 Series 11/32 x .120 wall 7.605/7.640 length push rods that I had on another motor with 360-2 heads that have about 15 passes on them. The engine broke a rod. If they will work I will sell them cheap. Ball, Ball? The exhaust are a right but the intakes are a little long. I've only measured one side will try to get the other side measured tomorrow. Yes, Ball-Ball..
[Re: justinp61]
#1971940
12/18/15 02:50 AM
12/18/15 02:50 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Trend made mine , any length that i needed.
[Re: CSK]
#1971952
12/18/15 03:10 AM
12/18/15 03:10 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have used Trend, Smith Bro, and a local copany to me.. they make what I want in straight PRs.. its called OEM.. I never had any bend or break.. but Smith Bro were way pricer than Trend and way more than OEM... OEM makes Comp Cams PRs EDIT its a small place but the guy took me in back to show me around and I was watching the one machine putting the Comp Cams name and length on them going into boxes.. pretty simple process on PRs but they do nice stuff
[Re: justinp61]
#1971958
12/18/15 03:16 AM
12/18/15 03:16 AM
Posts: 4,213 New York
polyspheric
New York
"Not enough pushrod" doesn't always produce results that are easy to see and diagnose. A limber pushrod acts like pole doing a pole-vault - it bends when the load vs. speed is too great, then snaps back to full length and overloads the spring. SpinTron is excellent in diagnosing this, but it's cheaper to just use the biggest diameter you can fit. Sometimes, it isn't float or breakage - it's a soft spot in the RPM range you use that goes away when the pushrod is stiffer (not stronger).
Boffin Emeritus
