neutral safety switch help #197193
01/18/09 02:51 PM
01/18/09 02:51 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
on a 1966 how do the reverse lights work with a one pin nuetral safety switch , traced the light wires all the way back and it ends up at the fuse box,can't find any other switch to activate the lights,am I missing something here ?
Re: neutral safety switch help [Re: 426lloyd] #197194
01/18/09 02:54 PM
01/18/09 02:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The earlier years with the one terminal neutral safety switch the reverse lights are controlled by a seperate switch either on the column for column shift or at the floor shift.
Re: neutral safety switch help [Re: NITROUSN] #197195
01/18/09 02:58 PM
01/18/09 02:58 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
thanks , just found it,it is on the steering colom as you said thanks
