replacing front brakes kicking my [censored] #1970887
12/16/15 04:23 PM
12/16/15 04:23 PM
md
mopars4ever Offline OP
md
My 06 ram 2500 4x4 needs front brakes. I have been avoiding doing it because of the amount of rust on everything. Well I started to work on them today. They are kicking my [censored]. After a can of PB rust blaster, heat and hammering on the left rotor it finally came off. Next I was going to retract the pistons on the caliper and noticed the pistons are covered with rust on the exposed edge. I tried to remove it the best I could but the piston won`t go back in far enough to get the caliper back on. So I bought new/rebuilt calipers and hoses from NAPA. (that`s a whole other story)
Well I went to replace the front rubber brake hose and the fitting on the metal brake line from the HCU won`t break loose. I got the hose off by removing the metal clip and spinning the hose off but the fitting won`t spin for me to be able to tighten. I don`t want to heat the fitting because the metal line has a plastic? coating. I ordered a new line from the dodge dealer but it will be 3-5 days to get.
Man this sucks.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1971151
12/16/15 11:22 PM
12/16/15 11:22 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
No offense but I can't believe the number of rust belt posters here who don't know how to make a brake lines be and get new ones from the dealer.
It's really not the hard to bgend and flare new lines yourself.
Angry white pureblood male
Re: replacing front brakes kicking my [censored] [Re: ruderunner] #1971235
12/17/15 01:26 AM
12/17/15 01:26 AM
IN
ahy Offline
ahy  Offline
IN
If the hard lines are seized up and won't spin, I have learned (the hard way) best to just nip them off with a bolt cutter and make new. I got a 20' coil of brakeline from AZ and bend and flare them up. My hand bent replacements do not win beauty contests but have been trouble free.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1971256
12/17/15 02:13 AM
12/17/15 02:13 AM
md
md
I have cut and flared lines before on my old stuff without issues and I was going to do that but the flare end of the line looked different from the normal flare. Just wanted to be safe. Plus my eye sight sucks anymore.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1971396
12/17/15 01:18 PM
12/17/15 01:18 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Brake lines are typically a double flare. Requires a special tool to remake them vs the standard single flare.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1971410
12/17/15 01:50 PM
12/17/15 01:50 PM
md
md
it wasn`t a double flare. it was more like a bubble flare.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1971524
12/17/15 05:01 PM
12/17/15 05:01 PM
Guitar Jones Offline
The bubble flare is a metric flare, you can buy the tool to make them as well.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1971604
12/17/15 07:28 PM
12/17/15 07:28 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Yep, missed the fact it was an 06, the newer ones often have the bubble or metric flares, they're a bit more difficult without a real good tool, (at least for me). The one Mastercool makes is real nice, if a bit spendy.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1971690
12/17/15 09:41 PM
12/17/15 09:41 PM
md
md
Well the new line will arrive on Friday. It was only $16 or so. So at least I know what type of flare to use for the next time. BTW, I was using PB blaster on the rusted rotors to get them off. The can ran empty and I went to Tractor Supply and they had some WD40 rust penetrate spray. Man , that stuff worked much better. It dissolved the rust much better.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1974203
12/22/15 12:28 AM
12/22/15 12:28 AM
md
md
Got the new line on. Now my brake pedal isn`t like it really should be. It seems to be a little spongy. I bled all four calipers to where no air was coming out. I was reading online that air can get trapped in ABS unit and a scan tool is needed to release it. Is there any way to doing it without gong to the dealer? BTW, I did double check for leaks and I had good flow to all the calipers.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1974256
12/22/15 01:06 AM
12/22/15 01:06 AM
ky.
K
kenworth_goose Offline
K
ky.
I would drive it for a few days, then bleed them again. Any air in the system will work it's way to the bleeder.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1974257
12/22/15 01:08 AM
12/22/15 01:08 AM
ky.
K
K
ky.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1974690
12/22/15 06:19 PM
12/22/15 06:19 PM
md
md
Yea, I will give that a try and bleed them again next week.
Re: replacing front brakes kicking my [censored] [Re: mopars4ever] #1975485
12/24/15 12:35 AM
12/24/15 12:35 AM
IN
ahy Offline
ahy  Offline
IN
I had a similar spongy pedal problem after service on an ABS equipped Jeep. With one day before it needed to start a 2,000 mile trip loaded to the roof + trailer, I took it a shop for pressure bleed. That fixed it.
