Squeaky upper control arm bushings!!???
#1970973
12/16/15 06:48 PM
12/16/15 06:48 PM
Posts: 1,567 Ky
jt4406
Ky
I replaced all the control arm bushings in my 70 challenger while restoring it. Had it on the road about a year now and about 6 months ago, got tired of hearing the passenger side upper control arm squeak, so I replaced both bushings (again, used the offset one in the front position for increased positive caster). Solved the problem immediately, although when removed, you could not make the bushing squeak or slip in the arm, looked perfectly fine. Now the driver side is squeaking!!! What's up with that?
Jess
Yeah, it's hopped up to over 160...
Re: Squeaky upper control arm bushings!!???
[Re: jt4406]
#1971051
12/16/15 08:44 PM
12/16/15 08:44 PM
Posts: 1,954 Illinois
SGTFURY62
Illinois
It's jealous. Yank that side and replace as well is what I'd recommend. Unless you did both sides this time already. Maybe it's the material they used in that run of bushings and the one side was weakest and squeaked but now with newer pieces the other prior bushing sides chiming in from stress??
[Re: jt4406]
#1971118
12/16/15 10:44 PM
12/16/15 10:44 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Mine squeek occasionally after a good rain. I spray them with Zep45 (any light spray lubricant should work) and they stay quiet for another 6 months.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jt4406]
#1971164
12/16/15 11:34 PM
12/16/15 11:34 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Make sure the cam bolts are good and tight. My 72B had a squeak after rebuilding the front end. I went back and tightened the cam bolts down real tight and the squeak went away.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: jt4406]
#1971174
12/16/15 11:50 PM
12/16/15 11:50 PM
Posts: 1,567 Ky
jt4406
Ky
"tighten the upper control arm bolts with the suspension loaded".....yes, made sure suspension height was adjusted to where I wanted it BEFORE I tightened them.
"cam bolts are good and tight".....yes, did this when I performed the alignment.
"spray them with Zep45".....didn't use Zep45, but I did try two or three silicone based lubricants on the pass side, nothing helped except replacing them.
"Something is off with the original bushings. Agree good idea to replace the other"......I'm in agreement with this, "the material they used in that run of bushings" probably...though I haven't tried spraying the driver side. Most likely I will have to replace them.
Thanks for the replies, Jess
