Radiator hose temps?
#1970684
12/16/15 03:39 AM
12/16/15 03:39 AM
Posts: 1,970 ID/MT
Cheeto
ID/MT
Picked up a winter beater/dump runner/landscape supplies hauler. Has a 3.9 V6. Vehicle calls for a 195* thermostat.
Problem is good airflow from heater but poor heat. I was getting ready to back flush the heater core but happened to have my infrared temp sensor handy so I checked all the hoses.
Readings were taken after running errands for an hour (ambient temp was about 40*F), gauge is about 1/4 of the way between "C" and "H".
At hot idle the upper radiator hose reads 150-160* depending on exactly where I point the laser. The lower hose I don't recall but it was plenty cool.Heater hoses read 140* and 130* with the heat selector on full and fan on #2.
Do I have a clogged heater core or is the t-stat stuck open/missing?
Cheeto It's not perfect. It's not correct. It's not yours!
Re: Radiator hose temps?
[Re: Cheeto]
#1970691
12/16/15 04:19 AM
12/16/15 04:19 AM
RapidRobert
the t-stat stuck open/missing? that would be the first thing I would check
[Re: Cheeto]
#1970992
12/16/15 07:30 PM
12/16/15 07:30 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
One other thing, lack of heat to the heater is usually the first sign of low coolant, wouldn't hurt to check.
[Re: Morty426]
#1972450
12/19/15 12:58 AM
12/19/15 12:58 AM
Posts: 10,631 Freeport IL USA
poorboy
Freeport IL USA
I have a 99 CTD and he heater has sucked donkey balls since day one.
And I live in CA where it never ever gets below 25. Ever Did you buy it new? Have you ever changed the thermostat? Has the system ever been back flushed? A 195 thermostat will help a heater put out more heat than a 180 thermostat will. If the stat has been changed and the heater still sucks, I would look at the blend doors in the heater unit and be sure all the doors are opening and closing like they are suppose to. I've also heard the the radiators are so big on the diesels that the coolant never can stay at the stat temp. On those, you have to restrict the amount of air passing through the rad in the winter. But then, that falls into the troubleshooting area I mentioned in the earlier post, doesn't it? Gene
[Re: Cheeto]
#1972802
12/19/15 05:52 PM
12/19/15 05:52 PM
Posts: 1,970 ID/MT
Cheeto
ID/MT
I put in a new 195* thermostat (the old one was a 195* and was complete) and flushed the heater core both directions until I got clear water both ways. Lots of rusty water, no noticeable chunks. Admittedly this was hard to do in 28* weather when the end broke off the garden hose. Topped off the coolant (I always drill t-stats if they don't have a vent)in the rad and overflow and took it for a drive...low heat output. The rad needed about another cup of coolant the next day...still low output. The core was flowing clean water although I can't say if it was flowing as well as it should since my garden hose/heater hose mating wasn't optimal.It was a solid stream coming out but my water pressure is about 70 psi so it was spraying all over the place on the inlet side. Me and the hose were like The cable adjustment has good tension and I can clearly hear the "klump" of the blend door opening and closing when sliding the heat selector back and forth. It took a long time to get the feeling back in my hands and I likely will need a new garden hose come spring so right now I'm just going to think on this one for a bit. If anybody has a first gen Dakota and an infrared thermometer I'd appreciate if you could check your hose temps against mine.
[Re: Cheeto]
#1972984
12/19/15 11:23 PM
12/19/15 11:23 PM
RapidRobert
actually that was a good thing that you inadvertently modulated the hose psi into the heater core cuz it ain't meant for anywhere near 60 psi. it may or may not handle 60 but it dont take that to clean it out. I'm thinking from your descrip that the core is flowing well enough (especially with the backflush) & that the prob (the heater core heat output) is elsewhere.
[Re: RapidRobert]
#1973059
12/20/15 01:28 AM
12/20/15 01:28 AM
Posts: 2,046 ky.
kenworth_goose
ky.
actually that was a good thing that you inadvertently modulated the hose psi into the heater core cuz it ain't meant for anywhere near 60 psi. it may or may not handle 60 but it dont take that to clean it out. I'm thinking from your descrip that the core is flowing well enough (especially with the backflush) & that the prob (the heater core heat output) is elsewhere. I've always used compressed air to blow them out and have never had one leak after. I'd change the core if you don't get heat after blowing out and also check the blend door while you have the box out.
[Re: kenworth_goose]
#1973080
12/20/15 02:11 AM
12/20/15 02:11 AM
RapidRobert
I've always used compressed air to blow them out and have never had one leak after. Alright but I think a core would need a liquid going the other way (reverse flush) to get the loose debris out of there
[Re: RapidRobert]
#1973102
12/20/15 03:21 AM
12/20/15 03:21 AM
Posts: 954 garnett kansas
rhad
garnett kansas
ive had 2 dakots that had heater problems,i replaced the core on both of them,one works great,the other just wont make much heat,all the doors etc work as they should,i even put a 205 degree stat in it and it just gets slightly over warm air,never could figure it out i have also pumped warm oxiclean water both ways thru heater cores with good success
my ladder of success is missing some rungs
[Re: dsp]
#1973676
12/21/15 04:41 AM
12/21/15 04:41 AM
Posts: 1,970 ID/MT
Cheeto
ID/MT
The heater hose has an air lock and needs bled. The same thing happens to my '94 3.9 Dakota. One of the heater hoses loops way up and over the engine and is prone to air locks. I cut the hose at the top of the arc and installed a Prestone flush & fill tee. If an air lock develops, I loosen the cap and let the air out. This has been in the back of my mind. The truck has exactly what you describe already installed in the upper heater hose. My hands were too dang cold to loosen that cap the other day so I hoped for the best. I'll put more effort into that when I get back to it. My other thought was maybe the impeller on the pump is rotted away and I'm just not getting enough "flow" for the heater.
[Re: Cheeto]
#1974299
12/22/15 02:29 AM
12/22/15 02:29 AM
poorboy
Freeport IL USA
How big is the hole your drilling in the thermostat? You need to bleed the air at that top heater hose. A good rad cap is required to keep the coolant full any place near the top of the rad level. Once the air is purged from the system, it needs to remain sealed or the air pockets return. Any coolant leaks increases the chance for air to get back into the system.
Does the temp gauge show the motor is warming up? If it does, check the temp at the outside of the heater core with your inferred, both sides should be the same temp. If the temp varies more then 10-20 degrees, the core could be the problem. Turn off the heater fan for this test! The heater fan can cool down the heater core by several degrees in a very short time, especially if its cold. Check metal fittings if possible. Hoses do not give good readings.
Though a real temp gauge with numbers on it would be better, you can get an idea of the motor temp with your inferred at the intake manifold just below the thermostat housing. You can also check the temp of the rad core tubes at the bottom and at the top of the rad. You can see about what temp the coolant is flowing through the motor. You have to check the temp of the metal that surrounds the parts the coolant flows through for the most accurate numbers, and they will still be off a bit, but if everything is checked the same way, you can get an idea of what its doing.
I have to ask, how long is the motor running before you are expecting heat? If everything is working properly, it will take at least 10 minutes running time before the system BEGINS to produce heat, and another 10 minutes to show heat in the cab. If you have the heater fan on high during this time, you can almost double those times! Its amazing how many people have the heater fan on high and wonder why it takes so long for the ride to warm up. Are you expecting that little heater core to displace all the cold air in your cab instantly, but your not even letting it warm up first? Gene
[Re: poorboy]
#1976955
12/27/15 03:10 AM
12/27/15 03:10 AM
Posts: 1,970 ID/MT
Cheeto
ID/MT
How big is the hole your drilling in the thermostat?It's the smallest bit in my set. Maybe the size of a ballpoint pen tip. You need to bleed the air at that top heater hose. A good rad cap is required to keep the coolant full any place near the top of the rad level. Once the air is purged from the system, it needs to remain sealed or the air pockets return. Any coolant leaks increases the chance for air to get back into the system.
Does the temp gauge show the motor is warming up?See post #1 If it does, check the temp at the outside of the heater core with your inferred, both sides should be the same temp. If the temp varies more then 10-20 degrees, the core could be the problem. Turn off the heater fan for this test!Good point. I failed on that one in my original testing. The heater fan can cool down the heater core by several degrees in a very short time, especially if its cold. Check metal fittings if possible. Hoses do not give good readings.
Though a real temp gauge with numbers on it would be better, you can get an idea of the motor temp with your inferred at the intake manifold just below the thermostat housing.There is no easy access to this area on a 3.9 with A/C in a Dakota with the engine running. You can also check the temp of the rad core tubes at the bottom and at the top of the rad. You can see about what temp the coolant is flowing through the motor. You have to check the temp of the metal that surrounds the parts the coolant flows through for the most accurate numbers, and they will still be off a bit, but if everything is checked the same way, you can get an idea of what its doing.That's why I was asking anybody with a Dak to repeat my measurements in the areas mentioned. Kind of an "apples-to-apples" scenario.
I have to ask, how long is the motor running before you are expecting heat?See post #1 If everything is working properly, it will take at least 10 minutes running time before the system BEGINS to produce heat, and another 10 minutes to show heat in the cab. If you have the heater fan on high during this time, you can almost double those times! Its amazing how many people have the heater fan on high and wonder why it takes so long for the ride to warm up. Are you expecting that little heater core to displace all the cold air in your cab instantly, but your not even letting it warm up first? Gene
